loader limits
   / loader limits
Me too.
With a TC34DA
   / loader limits #13
My tc29 will lift higher at higher RPM. I think if you would have raisedd RPM up you MAY have lifted it a little higher as the pump would develop max. pressure and if load was too much, relief would have kicked in.
   / loader limits
Now I am pretty sure I had the throttle set low. I was moving fire wood skids today , pretty heavy , and I could here the relief valve kick in right away. It did not do that when I was trying to lift the roof panels.
   / loader limits #15
My view point on this situation is this. The loader was built for a certain load limit. It will probably lift more, but unsafe things will happen. such as bend or breaking the front axle. I believe the specs are at the pins where the bucket is hooked . The closer you get the load to this point, you can lift the limit for the tractor. Pressure is what provides the force, and if you have a good pump, the pressure will be the same through out the rpm range. The rpm provides the GPM's which gives you the speed of operation. If your FEL quit lifting, then the full pressure was not getting to the cylinders. It could have bypassed in the pump, or by the spools, or the pump is worn. I had this situation, and I could only lift about half the rated load, and thought the problem was valve, but it checked good and then rebuilt the cylinders. I finally replaced the pump, and I am now lifting the rated load.
Your valve will only relieve when the cylinders can not handle any more fluid, and the pressure builds up until the relief setting is met. If the relief is working, that tell you that the pump is operating close to max. If you put a gage in the hyd circuit, you can see the pressure readings.
   / loader limits #16
At low rpm, your flow is so low that lifting the relief may not make enough noise for your to hear it over the engine. At higher rpm, the additional gpm flow would cause the relief to hiss/squawk much louder and be easier to hear. My guess is that at low rpm you exceeded your loader limits and the relief valve was lifting even though you did not hear it. As J.J. suggests, only a pressure gage could tell for sure.
2021 Kubota RTV X900 4x4 Utility Cart (A55787)
2021 Kubota RTV...
UNUSED FUTURE FT-GR87 87" HYD GRADER (A57193)
UNUSED FUTURE...
2020 Freightliner M2 106 Elgin Eagle Series 4MF Street Sweeper Truck (A55852)
2020 Freightliner...
Informational Lot - Shipping (A56435)
Informational Lot...
CATERPILLAR 908M WHEEL LOADER (A52707)
CATERPILLAR 908M...
Air Chipping Hammers (A55851)
Air Chipping...
