Box Scraper Box blade weighting, do you add weight?
   / Box blade weighting, do you add weight? #1
dex3361
Elite Member
N. of Charleston WV
Kubota L4400-1 HST,FEL, 3x3 remotes, TNT. BX1500 54 mmm
I have a 7 foot BB on my L4400 Hst and I have found that if I am doing any aggressive work it needs weight to heelp it into the ground even with the ripper shanks. Do any of many members add weight to their BB or am I alone here. I added a 8" Box Tube off of my old tractor onto the BB to use as a weight box here are a few pics of yesterdays work. I will have to wait for it to warm to paint though.
   / Box blade weighting, do you add weight? #2
Weight is your friend when it comes to box blades. You will find that many many users add weight to their box blades.
How much do you figure your blade weighs and how much weight have you added?
Just wondering. :confused:
   / Box blade weighting, do you add weight? #3
That should help you alot, what do you think the total weight is now? I know my 7' boxblade weighs about 1250 lbs.
Steve
I have 6 plates that weigh 84 pounds a piece. I add or take away as needed. the box blade is a no name brand that have beefed up quit a bit and I would say it weighs about 600#. I figure fully loaded its about 1100#.
Steve
What kind of box blade do you have? Do you have a few pics of it?
   / Box blade weighting, do you add weight? #6
No, you're not alone.
   / Box blade weighting, do you add weight? #7
I have a Frontier BB1284 with hydraulic scarifier teeth, top and tilt hitch.
Steve
I would say not. I had previously had my plates just C-clamped onto the BB and it was hassle. Do you know how much your blade alone weighs?
That is a beefy blade and probably doesn't need weight. I have thought about making my scarifiers Hyd. but that is way back on the project list.
   / Box blade weighting, do you add weight? #10
No I really don't. It is not that heavily built tho. I mostly use it as a counter weight while duing loader work and for pulling snow away from the garage doors.
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A55745)
2020 INTERNATIONAL...
2020 DRAGON ESP...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
SHOPMADE MANIFOLD TRAILER (A58214)
SHOPMADE MANIFOLD...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
UNUSED KJ 11' X 19' ALL - STEEL CARPORT (A52706)
UNUSED KJ 11' X...
