how hard to wire in concrete block?
   / how hard to wire in concrete block? #21
2manyrocks
Is there only one breaker in that panel?
If so I'd move it out side run new wires to the breaker panel elsewhere.
and ask forgives if the inspector catches it just my opinion.
tom
One 200A breaker.
   / how hard to wire in concrete block? #23
One 200A breaker.
If the existing panel is raintight move it out side if not replace it.
Inside put a female connector on the original threads and continue conduit down to an LB and in to the back of the new/ moved panel through the block replace wire with longer ones to the main panel.
tom
   / how hard to wire in concrete block? #25
The fire department would also much prefer to see that switch on the outside .
The fire department generally trumps the building dept.
Yep its easier for the owner to get reconnected by not pulling the meter !
tom
The label says it's rain tight. Got all the block laid today. I stayed up late tearing everything out that was in the way of laying the block and ain't much good for nothing right now.
   / how hard to wire in concrete block? #27
2manyrocks
I didn't think of it till last night if you have a main breaker in the other panel you don't actually need one before it.
tom
I had the block layers lay the block without extending the walls and it looks fairly proportional. So I will have to deal with the electrical box as I go along.
Lincoln Electric 225 Ranger Welder Generator (A52377)
Lincoln Electric...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A54313)
2019 KENWORTH T680...
2001 HAULMARK ELITE II 8' X 24' CARGO TRAILER (A51247)
2001 HAULMARK...
2007 Bomag BW120AD-4 Tandem Vibratory Smooth Drum Roller (A52377)
2007 Bomag...
JOHN DEERE 1700 LOT NUMBER 17 (A53084)
JOHN DEERE 1700...
