Tractor 4WD 20-30HP w/ 72" deck
   / Tractor 4WD 20-30HP w/ 72" deck #12
Massey Ferguson is offering 0% down, 0% interest for 72 months and up to $1000 rebate on compact utility tractors. You might want to check out the MF 1500:
MF 1500 Series
   / Tractor 4WD 20-30HP w/ 72" deck #13
That looks like the tractor I want, but way too far from me, and I'd doubt the dealer wouldn't take a long distance trade. I like that better than the X series b/c it's more like a real tractor.
The X seems like a beefed-up garden tractor.
The X series are garden tractors is why it seemed like a garden tractor.
   / Tractor 4WD 20-30HP w/ 72" deck #14
Have you thought about getting a used BX?
Yes, the only thing is I wouldn't get a warranty (or just a little bit of a remaining warranty). The JD X has a 4 yr/700hr warranty.
Basically, the only think the X doesn't have is the 72" deck. Otherwise it's OK on price, engine, 4wd, hydro.
Does anyone make a very large garden tractor with a 72" deck?
MF 1500 Series
The 1528 is the smallest MF that can take a 72" deck. It's like $16,000 :eek:
   / Tractor 4WD 20-30HP w/ 72" deck #17
Having been SCUT shopping fairly recently, I can say I don't recall any 20+ hp, under $10K tractor that is offered with a 72" deck. I think about the closest you could come is a BX2360, JD2305 or the like with no attachments and then get a 72" rear finish mower. I think you might be pushing the PTO hp limits, but going bigger on the tractor puts you further over your $10K limit. Maybe a slightly used version with some remaining warranty would fit the bill. I know the BX1860 (18hp) lists at about $9K for the basic tractor, but I don't think you can run a 72" RFM off of it. The 2360 is over $10K list. Kubota use to include the loader valve in the base price, but I don't know if they still do. If so, you can delete that for some savings.
Can't go rear finish mower, gotta be MMM.
Closest I got so far (new) was the Deere X748, but only 62" cut. Gonna see if there's a used NH or Deere compact with a 72" that's low hours, maybe still under warranty.
   / Tractor 4WD 20-30HP w/ 72" deck #19
Yes, the Deere goes up to 62" on that model, most others max at 60". The 72" MMM requirement is tough if you want to stay under $10K with the deck. Good luck.
Yes, the 72" mower seems to be the deal breaker. I think it's because you need a longer tractor chassis to handle it and that costs big bucks.
I may go for the X here shortly unless something real interesting comes up.
SET OF (4) NEW 11R24.5 TIRES (A53843)
SET OF (4) NEW...
2003 Walk-Behind Automatic Seed Spreader (A54811)
2003 Walk-Behind...
2010 Nissan Sentra Sedan (A51694)
2010 Nissan Sentra...
JMR stump/trenching bucket (A53421)
JMR...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
