do you allways have to run tractor at full rpm for work?
   / do you allways have to run tractor at full rpm for work? #11
The best example of where not to run at full speed, would be a post hole auger. Nothing good will happen if you try that.
Aww come on...where is your sense of adventure!!!??:D
   / do you allways have to run tractor at full rpm for work? #13
My tractor has two PTO speeds(540/1000). By using the 1000 RPM option and running my engine at 1535 RPM gives me 540 RPM at the PTO, which I use quite often, adjusting ground speed so the engine isn't lugging
   / do you allways have to run tractor at full rpm for work? #14
I find that it is rare to run many engines at there fullest although depending on the job and what it is normally it is with PTO work(not post hole augers) that I'll run at full throttle.
For most work with the loader or backhoes one half to two thirds throttle works fine and allows the oil pressures to be up enough for good performance.
   / do you allways have to run tractor at full rpm for work? #15
IMHO, short answer = no.
Engine sound + implement performance will tell you alot more than just a static rpm gauge can. Course an rpm gauge is a nice feature to have tho.
The key to operating at the proper rpm is really a hit and miss type of goal, but thats why the throttle is variable :D
You want the best implement performance coupled with the least amount of wear and tear on the tractor.
In my particular circumstance, my BX23 doesn't make it's rated pto rpm (approx 3150 rpm)until it's nearly at WOT (approx 3300).
I very rarely run WOT but I do run at a hair or two below quite regularly.
exp:
1) Finish mowing = full pto rpm. This is because blade tip speed = best finish cut.
2) BH work = usually full pto rpm. I'm at the point where I want the max performance out of it when digging. I run lower rpm when using it with the thumb for lifting etc.
3) FEL work, depends on what I'm doing. Digging into compost/mulch requires alot less power than digging into clay.
4) transporting / grading etc. Varies per job.
My goal is to find the lowest rpm where the engine doesn't lug, the hydraulics work at the speed I want and tractor moves at the speed I want.
This usually ends up being very close to the rated pto rpm :D
YUMV
Dave
   / do you allways have to run tractor at full rpm for work? #16
Still attached!
:D Haha, that's really good! Why can't I come up with that kind of stuff.
The only time I seem to run full throttle is driving down my subdivision road in H so I can get back to my driveway quicker and maybe blow some carbon out of the engine. (I don't mow).
   / do you allways have to run tractor at full rpm for work? #17
Just my opinion here, not based on fact, but I think alot of people run to low of a rpm. I think they feel they are "saving" there engine by running at a lower rpm. To a point I think this is O.K. put I see people lugging there engnes at times. Open the throttle up and let it fly, this is really true when mowing. When I do end loader work, I tend to slow down the rpm to around 2100 becasue I'm smoother that way. 2100 seems like a pretty good setting on my BX, not to slow but not screaming.
   / do you allways have to run tractor at full rpm for work? #18
2100 is a nice setting for a BX. I do, however, have to step up from that to around 2500-2600 when getting into plowing, subsoiling and other ground engagement activities. Cannot see ever running it at 3100/3200 for anything, other than a momentary burst.
   / do you allways have to run tractor at full rpm for work? #19
I don't use my BX for mowing, but I do run it wide open when running my 4" chipper. But that's the only time I do. On a BX23 wide open is just slightly above 540 pto rpm. Since there is no tach on the BX23, wide open, or maybe just a touch under is close enough for me.
   / do you allways have to run tractor at full rpm for work? #20
I run a flail mower on the 1,000 RPM output at maybe 60% of the engine speed at which the 540 output goes at 540, so I am a little bit overspeeding on that.
It DOES give a nice cut, though I will probably pay for that some day in some way.
PHD I run WAY slow and I hold it back with lowering speed.
Rototiller, maybe down around 300. It is something I do by feel according to what I am finding, how deep I am going, etc.
I think attachments are generally built for a MAXIMUM speed of 540 or 1,000, but only a few of them (mowers, shredders, chippers) perform worse at lower speed and slowing down can reduce wear and the probability of damage when meeting obstructions.
2018 Skyjack SJIII4740 40ft Scissor Lift (A52377)
2018 Skyjack...
2018 Toro Workman GTX Electric Utility Cart (A54811)
2018 Toro Workman...
UNUSED 70PCS Black Metal Roof Panels (A53117)
UNUSED 70PCS Black...
Ford Pickup NR (A50323)
Ford Pickup NR...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
Scag Mower (A50324)
Scag Mower (A50324)
