do you allways have to run tractor at full rpm for work?
   / do you allways have to run tractor at full rpm for work? #21
When I mow I set my RPM on or close to the 540 mark (2300RPM) medium range on HST
With the Front end loader I usualy run at about 1800RPM in low range. The loader gets jerky at higher RPM.
Box blade and other I use whatever RPM works best usualy in the 1800 range.
Full throttle is about 3000 and I hardly ever get up there.
   / do you allways have to run tractor at full rpm for work? #23
Even when using the BH, I rarely go over 2k RPM, haven't had a need so far, but running a tiller then yeah, WOT, less chance of problems IMHO.
   / do you allways have to run tractor at full rpm for work? #24
I generally go by the manual; they designed and built it, so I figure it is a pretty good guideline. With experience, you will learn those instances in which going outside those parameters will work for you.
   / do you allways have to run tractor at full rpm for work? #25
I mow and brush hog at full RPM. Depending on what kind of loader work, I throttle back appropriately. I run the PHD @ low RPM.
   / do you allways have to run tractor at full rpm for work? #26
Is this info in the Kubota manuals? If so, I haven't been able to find it.
   / do you allways have to run tractor at full rpm for work? #28
Just my opinion here, not based on fact, but I think alot of people run to low of a rpm. I think they feel they are "saving" there engine by running at a lower rpm. To a point I think this is O.K. put I see people lugging there engnes at times. Open the throttle up and let it fly, this is really true when mowing. When I do end loader work, I tend to slow down the rpm to around 2100 becasue
*I'm smoother that way. 2100 seems like a pretty good setting on my BX, not to slow but not screaming.
*How do you do that with tractors that don't have a way to measure RPMs?
all very good info, but I am with lbrown on judging rpm .I have a bx2200 and it does not have a tach. on it.
   / do you allways have to run tractor at full rpm for work? #30
I think your best answer will come from time spent in the seat. After awhile you will get a feel for what is the right rpm for what you are doing. You develop a sense of how your tractor is behaving. It takes some time, but you'll see what I mean as time goes on.
2008 FORD F450 SERVICE TRUCK (A54607)
2008 FORD F450...
2013 CATERPILLAR 312E EXCAVATOR (A51406)
2013 CATERPILLAR...
2014 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A53422)
2014 Chevrolet...
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
LOAD OUT INFORMATION (A53084)
LOAD OUT...
