Cut 2" thick patio pavers
   / Cut 2" thick patio pavers #11
Grinder... I dunno. I'd rather get good with a brick hammer, much faster, equally likely to blow the bricks apart. Brick hammer isn't that tough to get ok at, though its pretty impressive to watch someone talented do it.
All you have to do is score the brick with the diamond wheel down maybe 1/2". I never cut all the way through-wastes too much blade & time. Then a couple taps with the brick hammer and it cuts. I also like the grinder with abrasive wheel for rounding the ends like the OP wants.
   / Cut 2" thick patio pavers #12
Here are a few pics of a paver patio we built last week. We used a small wet saw to make the cuts as needed. I use a plate compactor and concrete sand as my base. Grading is the key for a good appearance and allowing for some slope even though the water will run through the bricks..
   / Cut 2" thick patio pavers #14
Lookin good. How "square" were the walls you were working within?
Run in was about 3/4" over 30' of length, The far side of the steps was off nearly 1" in 4' though.
I have seen a lot worse.:D
   / Cut 2" thick patio pavers #15
I've had zero luck cutting with an abrasive wheel, I'd think the diamond blade is the way to go.
Can someone give a little more specifics on how to cut a 1/2 inch then break, it is the breaking part I don't quite get. Do you turn it over, oposite side of the cut and then tap over a stick or 2x4 or something of the sort. Anyway I can save blade time the better as far as I'm concerned, I've laid a brick walkway but stopped where I have to cut the final course.
Thanks,
Joel
   / Cut 2" thick patio pavers #16
Thanks,
Joel
Most of the bricks running down the right hand wall in the pictures above were all trimmed a minimal amount. What I do is score them about 1/2" each side free hand over a 4 1/2" diamond blade, Then tap with a light brick hammer to break them. Using the diamond blade set up with the wet base and no guides or fences is faster, a simple mark of line on the brick face is good enough.
I try to keep my fingers out of the way too.
Thanks for all the info,hope to get this done before winter really set's in. I have in the past laid several hundred Sq. ft of brick patio and walk's around our pool with no problem other than my 55 year old knee's, just never messed with trying to cut a radius. You know how it goe's [wife has this picture of this really nice small patio with a bistro set for in our landscaping,for somewhere where it would look good, looks like it should be easy] I belive that was how she said it. Thanks for all the info, maybe if I push it of till spring it will be forgotten. wishful thinkin
   / Cut 2" thick patio pavers #18
builder, I agree, but a wet saw is pretty fast and one step. Barring that you can skip the scoring and just go with the hammer if you are good (I don't do enough brick not to waste them, and I own the wet saw, so out it comes).
I do have a grinder with a diamond blade of course, and could see using it, but the masons I hire usually use a wormdrive with a diamond blade to cut brick when they do (usually 2" flag) because it has more juice.
   / Cut 2" thick patio pavers #19
That's exactly what I do. Just score them and a couple well placed taps with a brick hammer and the excess falls right off. Don't use the chisel side of the brick hammer, use the blunt side. I hold the brick in my left hand and just whack the excess piece.
   / Cut 2" thick patio pavers #20
Well "back in the old days" when bricks were fired clay, a mason could cut what ever shape you wanted with a brick hammer (I've tended for many of them). Now no mater where you hit them all you get is 2 halves :( you have to have a saw, the new modern bricks including pavers as well as veneer and structural bricks are a combination of highly compressed shale and cement with high heat.
For OP I have this one pic showing what I was talking about, doing the radius with the border bricks, then running the filler courses into it just trimming the corners to bring them in close.
For Joel with the final cuts, I would take as many bricks as I needed to the back corner of the yard where the dust wouldn't bother anyone and cut them with a 12" demo saw w/diamond blade. If you have this saw available that IMO would be the fastest way.
2013 KENWORTH T800 DAY CAB (A54607)
2013 KENWORTH T800...
2002 WACKER RD25 ROLLER (A54607)
2002 WACKER RD25...
2004 JOHNSTON STREET SWEEPER (A54313)
2004 JOHNSTON...
2008 AAR MOBILITY SYSTEMS REFRIGERATOR CONTAINER (A54607)
2008 AAR MOBILITY...
2019 FREIGHTLINER SPRINTER 2500 CARGO VAN (A54313)
2019 FREIGHTLINER...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
