Hello,
Our family runs a small, but widely diverse organic fruit and vegetable farm.
We own seven acres that we started the farm on, we farm about five of these acres, we also have access to ~20 acres down the road that we began using last season.
When we were using just the five acres we owned a Kubota
B7200, and
B8200, both 4WD with a FEL on the 8200. These served us well as they fit well in the tight spaces we were farming, and had enough horsepower to run the implements we used.
We have since sold the 8200, and have mounted a loader on the 7200, we also bought a Kubota L245H cultivating tractor as stepping up the acreage has made hand cultivation non feasible.
Working the larger fields is also impractical with the small Kubota and tiller we were using before, so we bought a Allis Chalmers 180 (~75 horsepower 2WD) to pull a four bottom plow, a 10' transport disc, and a 12' cultimulcher for field preparation. This tractor weighs upwards of 10,000# and when pulling the plow we need every bit of this weight even with brand new tires.
A few days ago we also bought an Allis Chalmers 160 as we needed a tractor with a short wheelbase that would go slow enough to pull our transplanter, the 160 will go close to .2 miles an hour in low gear at idle, this is something you may also want to keep in mind if you plan on using a transplanter in your operation.
We also do work in hoophouses, and have tight rows of brambles, this necessitates keeping the 7200 around as the other tractors won't work in these situations, we also have a BCS walk behind tractor for situations like this where the space is tight.
You really need to think through what exactly you will be doing as this can impact what should be recommended. We have less acreage than you have, but we have four tractors, they all have their place, and we would be in trouble if any of them were missing.
Can you give us a little better idea of what you're planning on doing?
With all that said I would recommend something in the 50-70 horsepower range with 4WD, a creeper gear, and a front end loader. I would also recommend looking into loaded tires so you have the weight to pull tillage equipment.
Let me know if you have any questions.
Erik Fellenz
Fellenz Family Farm
Welcome to the Fellenz Family Farm
