Oil & Fuel 2615 transmission oil
   / 2615 transmission oil #1
buck12
Mississippi
Kubota 5460HSTC
I am getting ready to service my 2615 gear for the first time. The manual seems a little confusing on several points including which fluid to use in the transmission. The lubrication table shows that for transmission/front diff. to use Citgo-Transgard Tractor Hydraulic Fluids, Exxon-Torque Fluid 56, etc.. The manual does not specify if this for a HST or gear drive transmission. Does this mean that HST and gear tractors use the same fluid? For those with 15 series gear drive what are you using?
   / 2615 transmission oil #3
I'm using Chevron for the transmission/front diff. and then Amsoil oil for the engine.
As always the information/advice provided by the members of this site is appreciated.
   / 2615 transmission oil #5
I used NAPA heavy duty hydraulic fluid in the transmission/front diff and Chevron Delo 400 in the engine.
Is that in the yellow bucket? I was at the local NAPA store yesterday for something else and noticed it was $26 per 5 gal bucket.
   / 2615 transmission oil #7
No. I have it as "NAPA Premium Universal Tractor & Transmission Fluid". Part NHF 85405. 5 Gals @ $55.83. They have changed the website and the 'refinements' just made searching much harder. The attached picture is the oil used. It also comes in gallon jugs. I think I used close to 7 gallons between the hydraulic's and front diff with some left over. Can says "Meets JD J20C, Quatrol Case IH, Hytran Plus MF Permatran III Specs".
Regards
   / 2615 transmission oil #8
7520 Engine Oil Change. Has anybody figured out how to fill this model up with new oil without it taking hours. This is a terrible design. It only takes a thimble at a time without running over?
   / 2615 transmission oil #9
I do not have a problem. I use a funnel and pour away. You have to drain the old oil out first.:confused3:
2005 International 4200 Texoma UC-301 Pier Drilling Truck (A52377)
2005 International...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A54313)
2019 KENWORTH T680...
2014 CHEVROLET IMPALA 4DOOR SEDAN (A54313)
2014 CHEVROLET...
R-134A Manifold Gauge and Hose Set (A55218)
R-134A Manifold...
