Storing gas in a propane tank?
   / Storing gas in a propane tank? #21
Storing diesel is MUCH safer than storing gasoline, one of the reasons it is used so much on boats. Gasoline has a very large range of air/fuel mixture at which it can combust/explode.
Ken
   / Storing gas in a propane tank? #22
just off the top of my head, you would definitely want a pressure relief valve. it doesn't have to be an open air vent, but something that blows off at 10-15 psi would accomplish your goal of keeping the fuel pressurized and outside air from entering the tank.
be careful what you use for pressurization. don't know if co2 dissolves in gas to an appreciable amount, but could form carbonic acid if any moisture is present in the fuel, then watch out corrosion! perhaps n2 or argon would be a better gas to pressurize with? or just use dry, compressed air if using the fuel fairly quickly.
1*as mentioned, epa can get expensive quickly if you have a leak. sometimes metal tanks are required to have bathtub retaining walls built around or under them as a secondary leak containment structure. this is especially important near water body such as lakes and streams.
amp
1* Are you talking about commerical or private parties?
   / Storing gas in a propane tank? #23
1*The commercial zoning my actually have more stringent fuel storage requirements.
2*Talk to your fuel supplier. He can tell you if the rig you want is even legal. No sense building a rig you can't get filled.
1*Commerical regulations do not apply to private parties .
2*My suppliers fills these / no problem.
   / Storing gas in a propane tank? #24
That is true, but so are regular gas tanks. That's why they rust out after time. :) That's why I have to be careful to keep water out - but I don't want water in my gas in the first place!
I'll look into what the fuel delivery guys say...though I am in industrial zoning, so I get away with a lot. :)
Except those are not completely sealed, and cannot hold any vapor pressure...plus, much more likely to be stolen from. If people think it's a propane tank, they're also probably going to think they can't fill a bucket with it. ;) With a propane tank I'm looking for something used, maybe even past it's pressure testing date, since I don't need it to hold 250+ PSI. If I got a regular gas tank around 250 gallons it would have to be new, and probably cost nearly the same.
Good Idea they won't deliver to unapproved set ups.
   / Storing gas in a propane tank? #25
Do firemen naturally assume that propane tanks full of, well, propane, are safe when they're burning? Or back to the first question I asked, is a tank full of gasoline anymore dangerous than a highly pressurized tank of propane?
I understand storing gas, in general, is dangerous, but, I also know that millions of people have a propane tank in their yard or a diesel tank in their basement...
*I don't see those as being any safer.
quote]I don't either.
   / Storing gas in a propane tank? #26
I recently spent quite a bit of time researching storing gasoline as I need it for my home defense fire pump. A few comments that may or may not be of use.
I would make sure your supplier will fill the tank.
*I recall a limitation of 60 gallons for home storage. It may or may not apply and I don't recall whose limitation it is, it may have been the EPA. There can also be insurance implications for larger amounts of stored gasoline.
You can get a vent for a 50 gal drum for petroleum storage. It vents pressure at 5 psi and vacuum at 4 psi. Justrite drum vents.
Zeuspaul
*What does this mean and how does it work ?
   / Storing gas in a propane tank? #27
OP said his property is zoned industrial so commercial regs do apply.
   / Storing gas in a propane tank? #28
The sixty gallon limitation came from the Chevron site and and references the Uniform Fire Code.
Quote
<i>
A 60-gallon metal drum is the only container approved by the Uniform Fire Code for the storage of more than five gallons of gasoline.
The Uniform Fire Code limits the amount of gasoline in residential buildings to the amount "necessary for maintenance purposes and operation of equipment," not to exceed a maximum of 25 gallons.
Note that local Fire Department regulations may supersede the Uniform Fire Code. When storing more that five gallons of gasoline it is best to check with your local Fire Department for local regulations.</i>
Technical Bulletin: Longer-Term Storage of Gasoline: Recommended Storage Practices
   / Storing gas in a propane tank? #29
The residential limitation of 25 gallons of gasoline is for gasoline stored in a garage attached to a residence. The Uniform Fire Code doesn't limit gasoline stored in a detached garage.
Storage of Gasoline
oops, that's for Canada!
The Chevron quote in my previous post indicates *inside residential buildings*. I don't think a detached garage is considered a residential building.
Zeuspaul
   / Storing gas in a propane tank? #30
Storage of Gasoline oops, that's for Canada! The Chevron quote in my previous post indicates *inside residential buildings*. I don't think a detached garage is considered a residential building.
Boy this would be a PITA for anyone trying to keep warm in their in their house for the winter.
Must have really efficient furnaces in their houses .
I mean 5 to 25 gallon lasting all winter .
Where do I get one of those furnaces. ;):D
   / Storing gas in a propane tank? #31
Do furnaces run on gasoline?
   / Storing gas in a propane tank? #32
Gasoline is way too dangerous for a furnace inside of a residence. The explosive air/fuel range is way too large. Just takes a small ignition source such as a light switch, etc. Fuel oil/diesel does not have the same vapor properties.
Gasoline as an upper and lower explosive ratios of 1.4 to 7.6, fuel oil is 0.7 to 5, propane is 2.1 to 10. That does not sound like they are much different. However, the difference is the ease of creating the vapors and the flash points. Gasoline is 10 x's more volatile than diesel or fuel oil and the flash point of gasoline is -45 °F and fuel oil is about 150 °F.
Propane and natural gas are potentially dangerous which is one reason why they add the oderants to it. But their vapors are light and mix well with air so less likely to have a localized high concentration as compared to gasoline vapors which tend to sink and pool which is why storing gas near a flame heated hot water tank is dangerous.
Ken
The more I think about it the more I think I should just get 4 steel barrels for 220 gallons of storage. I'm going to look into the idea of CO2 or other inert gas fill as somewhat of a fuel stabilizer and to keep moisture out. (possibly as the pumping mechanism as well) I don't plan on storing it for more than 3-6 months at most.
I still haven't had a chance to call around but my main hope is that I can buy 100% gasoline with no ethanol for "offroad use" but I'm not sure if that's legal here or not. I don't see any reason why not, since race fuel is legal....
   / Storing gas in a propane tank? #34
i have a 120 gallon propane tank i mounted on a axle and use for offroad fuel, not towed on the road, just around the property. i will get some pictures soon
   / Storing gas in a propane tank? #35
Use Nitrogen as it is inert . Vent the tank in hot weather and close the vent valve and cut in nitrogen when a vacuum forms in the cold. If you have a drain valve completely fill the air space with gasoline and then cut in nitrogen and drain 20% of the gasoline..The second method is easier..A pressure gauge is good and leave 5 PSI nitrogen press to check for leaks....Should not go down to 0 Psi or just cut in a regulator and look for n2 bottle useage.....Make sure the tank steel is thick(I use propane tanks)...I treat the tank with PRI stabilizer ...5 years should be easy for gas with alcohol and with Av gas(100LL) 10 years...I keep it for Generators.....Charlie
   / Storing gas in a propane tank? #36
Under no circumstance would I use an electric drill or any other tool that might cause sparks on a propane tank, "empty" or not. As for welding or cutting, forget it.
So, how are you going to plumb this tank for gasoline delivery and dispensing?
   / Storing gas in a propane tank? #37
Fill the tank with water and drill away....Tap it...Blow out the tank with a shop vac for a couple days.....It's dry here in new mexico..and enjoy....Old propane tanks are a buck a gallon here and usually because the propane fittings are leaking........pull them out put in black iron plugs and fill away...Leave space for expansion ...I use a hand pump to get the gas out....Filter it.I use lock tight 510 to seal threads..Charlie
   / Storing gas in a propane tank? #38
Spring Hollow - normally I don't nitpick, or play Safety **** (much anyway), but Propane is normally considered heavier than air. For this reason, propane vehicles are often prohibited from using parking garages, and in some areas, tunnels.
From Wikipedia:
"Propane is denser than air. If a leak in a propane fuel system occurs, the gas will have a tendency to sink into any enclosed area and thus poses a risk of explosion and fire. The typical scenario is a leaking cylinder stored in a basement; the propane leak drifts across the floor to the pilot light on the furnace or water heater, and results in an explosion or fire. This property makes propane generally unsuitable as a fuel for boats."
Propane - Wikipedia, the free encyclopedia
Wouldn't want to see somebody not realize the heavier-than-air risks with propane...... could be fatal. A few years back in Toronto a guy was working on his catering truck (roach coach) in his driveway at home. Had a propane leak, when parked in the driveway. The garage was below grade, under the house. The propane ran down the driveway, under the main garage door, and pooled in the garage. Boom - major house damage, but as I recall, fortunately no fatalities - if I'm remembering this correctly, that was just dumb luck though.
Play safe. D.
   / Storing gas in a propane tank? #39
I don't know what pressure compressed air will make gasoline combust, but that's kinda like how a diesel works, doesn't it?
I live in the middle of the ethanol producing plants in the nation and it would drive me nuts if I couldn't get real gasoline!
2015 Ford F-250 Pickup Truck (A59230)
2015 Ford F-250...
2017 TERRAMAC RT14 CRAWLER DUMPER (A60429)
2017 TERRAMAC RT14...
2013 JLG G6-42A TELESCOPIC FORKLIFT (A60429)
2013 JLG G6-42A...
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
9000 (A47477)
9000 (A47477)
2018 FORD F-450 XL SINGLE CAB FLATBED SERVICE TRK (A59823)
2018 FORD F-450 XL...
