Repair/mechanic tricks and or tips?
   / Repair/mechanic tricks and or tips? #561
Everyone that speaks the Queens Language knows that a Spanner is as explained below!:D:D
[In British English, spanner is the standard term. The most common shapes are called open-ended spanner and ring spanner. The term wrench refers to a type of adjustable spanner.[1]/QUOTE]
It is also an acronym for many other items.:D
   / Repair/mechanic tricks and or tips? #562
The tip I have is when you have a place where a bolt needs to be held and you can only use one hand and need to place a flat washer, a split washer, and a nut on I put a magnet on the top of the bolt , which now will hold washers in place until the nut can be started.
   / Repair/mechanic tricks and or tips? #563
Good tip!
If you can't get the magnet in place, a bit of beeswax works. You can get beeswax cheap if you buy a toilet bowl flange.
   / Repair/mechanic tricks and or tips? #565
Did you ever have trouble with big fingers trying to hold a small nut in a tight place to start a bolt? Have you tried double sided tape (sticky on both sides) on the end of a finger, then stick the nut to it; i.e., have the nut stuck to the end of your finger instead of trying to grip it to hold it in place to start the nut?
Bird, I used your Ideal!:thumbsup: I was working alone like most of us retired ones and was bolting something togeather and couldn't reach around far enough to hold the nut while trying to put the bolt thru the other side! It saved me from wainting till the wife got home to do the job! Thanks,:D
   / Repair/mechanic tricks and or tips? #566
moored4:
Thank you for bringing this thread forward with your comment to Bird. I had not seen this before but I can assure you that now I will have many hours of great reading entertainment as well as innumerable tips on how to make my shop time less frustrating, more productive, etc.:thumbsup::thumbsup:
   / Repair/mechanic tricks and or tips? #570
I wonder if they recycle them at the slaughter house. :confused:
They do.
The only cow magnets I saw as a kid were the ones after they had been in the cow.
2015 Ford Explorer AWD SUV (A51694)
2015 Ford Explorer...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2013 Buick Enclave SUV (A51694)
2013 Buick Enclave...
2021 Simex TFC 400 rotary cutter, like  new (A52384)
2021 Simex TFC 400...
2012 INTERNATIONAL MA065 FLATBED (A53426)
2012 INTERNATIONAL...
