5-20 weight oil - what do do with it
Status
Not open for further replies.
   / 5-20 weight oil - what do do with it #31
Goodness such hostility...calm down...
   / 5-20 weight oil - what do do with it #32
I agree with Ralph here but I use 0w-20 in all my engines if I can. And that is only for like 15 years.
Hope you have modern engines, or cool weather and keep the rpm up when under any appreciable load. If not, it would be one of those times you cant.
larry
   / 5-20 weight oil - what do do with it #33
Back in the late Sixties, I was working at a garage. I remember the debate when oil was changing from single weight to that fancy new fangle multi-viscosity. How vehemently opposed it was by the old timers who insisted that it was garbage and they'd never put it one of their cars. Only 30w was going in their engines, "cause that light weight stuff just cannot be any good." (only they didn't say "stuff").
Heard the similar sort of debate, arguments and opposition to 5w-30 when it first came into use. Same thing. "Too thin", "Your engine will burn up!", "I'd never use the stuff." etc.
Same old, same old. By now the OP has long since given up interest in any of our responses, I should think.
   / 5-20 weight oil - what do do with it #34
Different old, different old. Same old didnt understand multi vis rating. Different old did, and knew that the 10w30 just started thinner and didnt thin as fast with heat - reaching the same reduced vis that straight 30weight did at optemp.
We are talking 20weight here - not 30. 20weight is too thin to support the rod bearings in a generic [worn] old engine that may be used under varying conditions of load, rpm, and hi temperature. an automatic trans wouldnt be bad, but a stick would be likely to see a little lugging and squeeze out that last micron of oil wedge occasionaly, leading to repetitive damage.
larry
   / 5-20 weight oil - what do do with it #35
I agree. People who take it so personally have more than oil issues they need to deal with.:(
   / 5-20 weight oil - what do do with it #36
I was being nice. When I see WRONG, BAD advice posted somewhere like this, I feel it is important to correct it...too many people will read it and cluelessly take the advice of some stranger who doesn't know what he's talking about...
   / 5-20 weight oil - what do do with it #37
I'm not saying advice given on TBN is all good or all bad. It should be, however, the responsibility of anyone soliciting advice to differentiate between good and bad advice, or further research advice that is given to determine for one's self if it's good or not. Different strokes for different folks.
I do it the easy way. Ask around, and then do whatever I want to. Regardless of how good advice is, and for that matter my own personal opinion, sometimes you get and sometimes you get got.
   / 5-20 weight oil - what do do with it #38
My father has moved from the farm into town, and dumped a bunch of newly purchased oil at my doorstep. (not new enough to return). There are 8 bottles of Castrol 5-20. I assume this is for the honda or something. I would assume that my tractor, which takes 10-40 for Hydraulics, could NOT use this, although it would be nice if it could.
So, at the risk of being niave. I tihnk I have a bunch of 5-20 that has no purpose, other than maybe putting it in my diesel tank, right? I have nothing that I know of that would use this and unless I can mix it in with my Hydrualic oil I seen no future for it.
Sorry to spin off somewhere else on that other post. To answer your question, I'd burn it in my diesel (if I had one), or give it to somebody who might could use it. I don't have a vehicle that I use 5w-20 in.
   / 5-20 weight oil - what do do with it #39
Correcting what you believe is wrong advice is not an excuse to be rude or to violate the TBN Terms Of Service by insulting other members.
zmoz said:
I have seen a LOT of bad oil recommendations in my life, but that has to be one of the worst. 5w20 is fine for any engine SPEC'D for it. Not other engines! Especially not diesel engines, small engines, tractor engines, old American V8 engines, etc. To say "ANY" engine is outright stupid.
I couldn't agree more. Advice from someone with 31 years in the lube industry or 'the advice of some stranger'? Easy decision.
   / 5-20 weight oil - what do do with it #40
Advice from somebody with "31 years in the lube industry" is no different than any other "stranger" on the internet. For all you and I know he's making that up. And for what he's saying about oil I wouldn't be surprised.
Anybody that has half a clue about how oil works knows 5w20 will not work well in an engine not spec'ed for it, or even for high mileage engines that are spec'ed for it. This is why I find the bad advice from someone with "31 years in the lube industry" quite questionable. Most people in this post agree with me that this is not the right oil for most things.
As I said before, to say 5w20 will work well in "ANYTHING" is complete nonsense and nothing else. I don't care if I'm being rude, sometimes the truth hurts. When you're wrong you're wrong, no matter where you work...
Status
30059 (A53424)
30059 (A53424)
2013 VOLVO VNL64T TANDEM AXLE MID ROOF SLEEPER (A54313)
2013 VOLVO VNL64T...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
2019 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2019 FREIGHTLINER...
2020 Brenner 450 Gallon Skid Mounted Vacuum Tank (A52377)
2020 Brenner 450...
