making lumber, finally $2,500/board foot.
   / making lumber, finally $2,500/board foot. #21
Making Lumber? I milled several logs yesterda afternoon.:D
   / making lumber, finally $2,500/board foot. #22
What type of mill is that egon?
   / making lumber, finally $2,500/board foot. #23
That is an "Egon Mill".
I made it myself. After finishing I discovered it is basically the same as a Beam Machine.:D
   / making lumber, finally $2,500/board foot. #24
Do you have a set of spacers that fix the chain bar different distances away from the beam? Or does the round part slide further into the that traveling bracket holding the saw?
I'll bet it doesn't walk around on you much when sawing :)
Dave.
   / making lumber, finally $2,500/board foot. #25
It's quite stable. There are one inch spacers on the shaft.:D
It can produce square balks of lumber quite consistently. :D
It's also quite portable. Just the slider portion will work quite nicely. The stand you see in the picture is for smaller stuff or working in the yard.:D
   / making lumber, finally $2,500/board foot. #26
I thought it must be something like spacers. Great way to set up a mill Egon.
Dave.
2018 CATERPILLAR 303.5E2 CR EXCAVATOR (A52705)
2018 CATERPILLAR...
Hydraulic Power Unit S/A Towable Pump (A53421)
Hydraulic Power...
NEW HOLLAND C362 SKID STEER (A52705)
NEW HOLLAND C362...
Galvanized Livestock Wire Gates (4X Gates) (A55218)
Galvanized...
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
2009 International Frazer Bilt X-514 Ambulance (A52377)
2009 International...
