making lumber, finally $2,500/board foot.
   / making lumber, finally $2,500/board foot. #21
Making Lumber? I milled several logs yesterda afternoon.:D
   / making lumber, finally $2,500/board foot. #22
What type of mill is that egon?
   / making lumber, finally $2,500/board foot. #23
That is an "Egon Mill".
I made it myself. After finishing I discovered it is basically the same as a Beam Machine.:D
   / making lumber, finally $2,500/board foot. #24
Do you have a set of spacers that fix the chain bar different distances away from the beam? Or does the round part slide further into the that traveling bracket holding the saw?
I'll bet it doesn't walk around on you much when sawing :)
Dave.
   / making lumber, finally $2,500/board foot. #25
It's quite stable. There are one inch spacers on the shaft.:D
It can produce square balks of lumber quite consistently. :D
It's also quite portable. Just the slider portion will work quite nicely. The stand you see in the picture is for smaller stuff or working in the yard.:D
   / making lumber, finally $2,500/board foot. #26
I thought it must be something like spacers. Great way to set up a mill Egon.
Dave.
CASE 6591 T/A PORTABLE POWER UNIT (A51247)
CASE 6591 T/A...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
2008 FORD F350 XL SUPER DUTY DUMP TRUCK (A51406)
2008 FORD F350 XL...
2009 MULTIQUIP 25KW GENERATOR (A53843)
2009 MULTIQUIP...
2013 Ford F-650 Flatbed Truck (A51692)
2013 Ford F-650...
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
