Chains for mud
   / Chains for mud #11
Mud and chains on a Kubota B7100.:D
   / Chains for mud #12
Thanks to all for the advice. Chains it is. Now about the wet spots. There are a few areas that can't be drained so I'm thinking of putting down 1 1/2 to 2 inch black rock to bring up the trail bed. Any thoughts on that one.
You might try that in the bottom of the wettest part but would want to top it with something that can compact at least a little, or it will always be loose. If you have any native fill on your property that has some gravel in it you could dump that in there.
If you had to buy material then IMO a large process mix would be best. That's like the first material put under a road or what they make temporary driveways at construction sites with. sometimes just 4-6 inches will stabilize a bad spot, especially if your just driving small vehicles over it.
JB.
   / Chains for mud #13
JB.
Agree on the topping. If you have native rock laying around, even as big as 18", that would make a great base to build up the mixed sizes on. In Vermont, you must have a few rocks looking for a new home :) They might eventually heave up towards the surface a bit from frost over 5-10 years, but I don't think they would become obstacles. Water will actually drain through/across a bed of larger rocks.
Dave.
   / Chains for mud #14
+1 on the bigger rocks. I have a couple of areas that I filled with rocks ,then gravel. Makes a 'french drain" that even when wet can be driven across without sinking up to the belly :eek::eek:.
   / Chains for mud #15
Depending how deep wet area is...
I agree w/stones,something in the lines of river wash gravel mix w/stones.
If you can dig some of the wet soil out,dump gravel/stone than pack,put extra gravel/stones on wet area in time in time gravel/stones well settle.
   / Chains for mud
Thanks for all the help. I now have a good plan that will be set in motion as soon as the grounds frozen. Thanks again :)
   / Chains for mud #17
I agree with your thinking on the 1 1/2 stone, Like someone else said if its possible dig out the poor material if you can, If not use 1 1/2 if the hole is less then a foot deep otherwise the hole will continue to " pump" and stay mushy know matter how much 1 1/2 you throw at it , if you have a bigger hole then mentioned find the biggest rocks you can move and start packing them in, then top with item4 or shoulder stone , my industry has a bunch of different names for it , its generally 1" minus and the first thing we take out when screening crushed stone , it does not always work in wet areas , do to the dirt and fine material content !
   / Chains for mud #18
;)..Being belly hung one thing,but digging out and swating blackflies and there cousins can make one beware of wet spots.
I hit this thread looking for info on chains in the mud because where I'm retiring I'll see a lot of mud and right now I could use the chains in Northern Virginia to help clear my street. The last time Fairfax County saw snow like this it took them a week to get the street cleared.
Apparently nothing specific, but I'm running Turf tires presently, anybody have an idea how hard it would be to reconfigure chains when I finally buy a set of Ag tires?
And on the subject of blackflies and mosquitoes etc. At my land in Vt and Ms swatting is about as effective as urinating against the wind. You breathe heavier and attract more.
Better is to mod your diet - low on dairy and high on garlic or a mix of B vitamins. The garlic doesn't help until they are REAL close, but I've seen mosquitoes in Vt, Va, Ms and Ak land on me and take off. Which is good, because the ones in Alaska have been known to carry small pets and drain them dry.
   / Chains for mud #19
Changing from turf to ag would require alot of modding to the chain as ags are usually taller as well as narrower. It can be done, I mod all my chains as I get them as cheap as I can (buy the misfits)
Taking in or letting out the cross links takes a little time, adding to the length and adding a couple of new cross links is pretty easy, just get some extra chain when you buy your chains so you wont have to look to hard when the time comes.
As far as your weather goes, I've been watching it on CNN, it's supposed to be coming our way next, starting this afternoon.
I've got to get a few things done in preparation this morning. Going to my 96 year old friends to help him put his chains on his 8N, I know they are all torn up so I'll be making some repairs as well.
2006 Acura RL Sedan (A59231)
2006 Acura RL...
2013 Dodge Durango (A53317)
2013 Dodge Durango...
Case IH MX270 Tractor (A59814)
Case IH MX270...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59575)
2019 FREIGHTLINER...
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
2003 Freightliner FLD 120 Columbia (A56436)
2003 Freightliner...
