KWentling
- Joined
- Jun 22, 2002
- Messages
- 1,162
- Location
- Rozet, Wyoming
- Tractor
- Kubota BX22, Kubota ZD21, Kubota M7060
First blowable snow of the year so I got to try out the BX22 and the B2650 snowblower I mated to it. Single digit temps so I dumped a little Power Service in it and headed out. I tried putting a piece of 2" ABS pipe on the cutting edge and that lasted about 2 seconds and the auger grabbed it. I wondered if that would happen. Going to have to find some metal pipe and weld tabs to make a bolt on. Sheared one of the bolts on the auger so ran it back in the shop and replaced that. Back out the door and it works great other than trying to keep it out of the limestone in the drive. Blew snow for about an hour and parked it back in the shop to thaw out. Just went out to look it over to make sure everything stayed tight and noticed I left the fuel cap off. Crap. I can see that there is some snow in the tank and no doubt some grass judging by the surrounding area. So now what. Probably only a couple of gallons in the tank and I can drain that but with the goofy shape of the tank I doubt I'm going to get it all out without taking the tank off. I've had the tank off and it's not a lot of fun but doable. What would you do?
Kim
Kim
