Front mount belt driven snowblowers
   / Front mount belt driven snowblowers #1
sqdqo
Marquette Michigan
Massey Ferguson 492 w/Quicke Q750 loader
Are there any older front mount belt driven snowblowers 5'-6' out there? The only thing I can find are the Ford LGT types and looks like only up 42" or so.
   / Front mount belt driven snowblowers #2
Currently Gravely has a 55" one. RAD International makes it. Produits Rad Technologies
That is about the biggest single v-belt driven unit I'd think you'd be able to run. The one for my Rapid XZ is 50" and uses a gears and chain setup due to the load and speed.
Gravely isn't producing snowblowers now are they? Is Gravely's an older version?
   / Front mount belt driven snowblowers #4
Nope. Current models.
TRADITIONAL GRAVELY ATTACHMENTS & ACCESSORIES For Rapid M
885001 Gravely 30" Deck---(For Gravely Rapid-M Model Only**Requires Adapter Kit 785107, Long Drive 785007**) $461.00
885005 Gravely 40" Deck---(For Gravely Rapid-M Model Only**Requires Adapter Kit 785107) $838.00
885015 Gravely 44" Brush---(For Gravely Rapid-M Model Only**Requires Adapter Kit 785107**) $2,080.00
833007 Gravely 32" Snow Blower ---(For Gravely Rapid-M Model Only**Requires Adapter Kit 785107**) $1,484.00
885014 Gravely 48" Blade---(For Gravely Rapid-M Model Only**Requires Adapter Kit 785107, Blade Weight 785020, Skid Kit 785021 &
Hitch Kit 785019) $230.00
785116 Rapid M Electric Start Kit $549.00
785117 Gravely Rapid M Car Pusher - Fits 985401 & 403 $302.00
785107 Gravely Rapid M Adapter For Traditional Gravely Attachments (Required For Use With: 885001, 833007, 885014, 885015)
(Recommended One For Each Attachment) $171.00
785020 Blade Weight $118.00
785021 Skid Kit--Snow Blower---(For Gravely 48" Blade) $64.00
785019 Blade Hitch $171.00
785007 Long Drive (Required For Use With 885001) $621.00
XDZ-200 SERIES MOWER ATTACHMENTS (RAD)
892032 Implement Quick Hitch - Hydraulic lift For front mount implements (Fits 200 series with hydraulic Deck lift) $1,212.00
892008 Two Stage Snowblower - Quick Attach Head, Hydraulic lift, Fits 200 Series with Hydraulic Deck Lift (Requires Quick Hitch & kit
792045) $2,312.00
892011 Snow Blade - Manual Angle 15 deg. Left & Right, Hydraulic lift. Fits 200 Series with Hydraulic Deck Lift (Requires Quick Hitch &
kit 792045) $769.00
892009 Rotary Sweeper - Manual Angle 15 deg. Left & Right, Hydraulic lift Fits 200 Series with Hydraulic Deck Lift (Requires Quick Hitch
& kit 792045) $2,869.00
792045 Weight Kit $214.00
892013 Debris Blower - Quick Attach Head, Hydraulic lift, Fits 200 Series with Hydraulic Deck Lift (Requires Quick Hitch & kit 792045) $1,545.00
RAPID XZ OUTFRONT ATTACHMENTS
890103 RAPID XZ Two-Stage Snow Thrower, 50" width $2,413.00
890104 RAPID XZ Rotary Broom, 47" width, polypropylene brush, manual angling $2,898.00
890105 RAPID XZ Snow Blade, 60" width, manual angling $748.00
890019 RAPID XZ Foldable ROPS $491.00
890106 RAPID XZ Grass Collector, Hopper dump from seat collection system w/Deck mounted spindle driven blower $2,444.00
Those were current thru 12/31/09
10222 (A56858)
10222 (A56858)
Sterling 9500 (A56438)
2015 VOLVO L110H WHEEL LOADER (A60429)
2015 VOLVO L110H...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2019 Ford F-150...
2017 Case CX145D (A60462)
2017 Case CX145D...
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
