tractor mounted weed eater
/ tractor mounted weed eater #1
gordyy
Gold Member
North Dakota
cub cadet yanmar sc2400 Kubota F2560
I am recovering from the 5th surgery on my knee in 4 yrs and am told its about as good as it gets.
The problem I have is trying to come up with a way to do the trimming or weed eating without having to do a lot of walking.
I was wondering if anybody here has ever seen or built something like this?
I was thinking maybe use a highspeed hydro motor and maybe making it telescope out from the 3pt.
just wondering if anybody has seen anything like this while I enjoy building and fabricating things I hate to reinvent the wheel if it works
/ tractor mounted weed eater #2
Hello
I saw a rig that someone built to do fence rows.
I will do some checking and if I find it I will post the link.
It may give you some ideas.
/ tractor mounted weed eater #3
Years ago I ran across one, it was offset about 3 ft had a hyd motor and used old cut up V belt instead of string.It was on RT 7 NY VT line.
/ tractor mounted weed eater #4
There is an FEL mounted hydraulically powered sickle mower called the Samuri I believe. I cannot recall who makes it but the idea is simple enough. I'd imagine you could also just rig a weedwacker to one side of your bucket and drive down a hedgerow. Another possibility is the wheeled weedwacker that DR sells. That could also be adapted to mount to the FEL so you could just drive along.
/ tractor mounted weed eater #7
I remember this coming up before here, maybe a search will turn the threads up. A quick google turned these up:
http://www.tractorbynet.com/forums/attachments/9807-fence-line-trimmer.html
Weed Chopper
Weed Chopper
Fence Hog
Fence Runner the Grass, Brush and Weed Mower Trimmer
Swisher fence line trimmer
Swisher ATV Postmaster Trimmer — 6.75 HP, Model# PST67522 | Trimmers + Brush Cutters | Northern Tool + Equipment
(There was a thread here some years ago about someone making several mods to this unit that made it work a lot better.)
/ tractor mounted weed eater #9
Looks as if it should only be used by a professional on a professional course
Why do you say that? They look easy to set up and run and cost only about $1300 which is not that bad for a specialized hydraulic tractor implement. Check out the videos on their website. I'd say it would take about half an hour to set up the first time and ten minutes to master the technique.
/ tractor mounted weed eater #10
I am limited on walking - must use a cane so my DR Trimmer/Mower is now useless to me. DR will not accept it as a trade in on a self-propelled model.
I am thinking about how to mount it on the FEL. Need to figure out a remote throttle and a start switch. Also whether to mount on a QA adapter plate for better visibility. I have a 14" "beaver Blade " for it that has a chainsaw edge - should be good for brush too thick for the flail mower to cut.
A small electric actuator might work for the throttle then I could make a electric control cable with connectors at the front of the FEL
Vernon
/ tractor mounted weed eater #11
Im sure the setup is very straight forward. I was concerned about the safety aspects of its use. That cutter coming through long grass could easliy missed by an onlooker
/ tractor mounted weed eater #12
That is true I guess though presumably the operator knows the sickle is there and would not "mow" any onlookers. Compared to the ubiquitous bush hogs that can launch lethal projectiles at any moment I'd say a sickle mower is pretty safe. Even if it hit you, which would not be pleasant, it would nibble at ankles and be unlikely to inflict a lethal injury which is not true of a bush hog accident. I have a walk behind sickle mower (Garden Way) and feel sickles are probably the safest type of mower in general. They don't have any high speed whirling parts which is a major advantage safetywise.
/ tractor mounted weed eater #13
Jeez Louise I am glad I found this thread. I have been looking high and low for a vineyard trimmer and the cheapest I could find was BDI Machinery's acampo cutter bar.
This looks pretty good for doing 10 acres of dormant pruning as well as the summer pruning we do to get ready for harvest. Now I know the name I'll search the www to see if there's any good/bad info on them. If you look at their website, that vineyard video is exactly what I need. Thanks TBN, hopefully now my arms will shorten back to their normal length from holding the gas trimmer.
/ tractor mounted weed eater #14
just start using herbicide. Use glyphosate up close to anything that would need to be weedeated, like buildings poles and flower bed edges, then all you have to do is mow around and you can cover up to the edge, then you will only need to touch up to kill crabgrass and the other stuff that sprouts every few weeks.
/ tractor mounted weed eater #15
The DR company in Vermont has a 3 pt mounted trimmer you might want to investigate.. Looking that way myself.
/ tractor mounted weed eater #16
I saw one of these on display at the local fair. At the time I wondered if having a hydraulic cylinder swing it in and out would be better than the spring arm. But watching the video on the DR site makes the spring arm look suitable. Maybe having both (a spring mounted/anchored hydraulic cylinder, if possible) would be best.
It would be interesting to hear from someone who has one.
Edit: Their website has los and lots or reviews from customers, both pros and cons, on this product.
2016 PALADIN 22197MM SWEEPSTER 97" HYD BROOM (A60429)
2016 PALADIN...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
2004 Ford F-250 Ext. Cab Service Truck w/ Liftgate (A59230)
2004 Ford F-250...
2012 DIAMOND T TRAILER TRAILER (A58214)
2012 DIAMOND T...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
