Tractor tire chain spring tensioners
   / Tractor tire chain spring tensioners #1
shine
Northern Colorado
Kubota B2710
Got my tire chains from tirechains.com qualtity chains at a good price.To bad I got the spring tensioners with them. The only thing thats a bigger pita putting them on is takeing them off. I'll buy some bungies tomorrow.
   / Tractor tire chain spring tensioners #2
I got the chains with the cam lock type tensioners. I love them! They go on quick and stay tight all winter.
Get the solid rubber bungies... None of this braided rubber band stuff.
   / Tractor tire chain spring tensioners #3
Shine do you even need tensioners? There is no way your chains will come off is there?
   / Tractor tire chain spring tensioners #4
Been using bungee cord for 30 years. I use small link chain for hooks, cut just enough out of the link to allow it to slip on the side chains. Need to stretch the bungee cord a bit to get it in the home made hook.
   / Tractor tire chain spring tensioners #5
Tighteners are just window dressing, IMO.
Not needed and if anything, interfere with the cross links dropping out from between the lugs so they can do their job.
If the chains are too loose, then they should be shortened and fitted to the tire.
But, if one feels better with bungees or springs, that is fine too. Won't make fun of ya :)
   / Tractor tire chain spring tensioners #6
I also have the cam lock type but I use a small cable tie to make sure that if the chains loosen the cams won't open.
   / Tractor tire chain spring tensioners #7
I tighten mine down tighter than a skeeters tweeter, but I still need/use tensioners, I also tie off the locks and any extra links, don't want any surprises when I'm "out there" also don't like to hear them.
I've been surprised to hear lately that some don't use or prefer them. I've got 2 CUTS and 2 garden tractors with chains and always felt I needed them (the tensioners).
JB.
   / Tractor tire chain spring tensioners #8
I got my chains today from tirechains.com. The spreader is a bit flimsy and a bit of a pita to attach, but with enough breaks to warm my numbing hands and the appropriate amount of foul language, I got the chains on tight enough so they probably aren't really needed anyway. The industrial tires make it a lot more difficult to get the chains on right than auto tires or turf tires. On cars, at highway speeds, the chains wear a lot faster and loosen up quite a bit, but here on snow and ice with dirt underneath and at tractor speeds, I don't expect there will be enough 'wearing in' to even notice.
After a lot of thought on the matter, I decided to put chains on front tires only. I know a lot of people don't like that idea, but given the relatively light usage the tractor gets in the winter and the fact that almost all of my actual plowing is downhill, and more momentum driven than traction driven, I don't think it's going to put too much strain on the front drivetrain. I guess I'll find out though..
   / Tractor tire chain spring tensioners #9
If you ever had to put a 200 pound chain on in a mud hole or in the middle of a blizzard with the wind blowing up your shirttail you would see the need the need for tighteners
been there/done that:(
Tom in Vermont
   / Tractor tire chain spring tensioners #10
Tom in Vermont
I've been putting my chains on IN THE BARN, BEFORE I NEED THEM for 35 years or more and I also say if you know how to install chains, you don't need to use a bunch of crap to keep them on. I do tie off the free links of the side strands on the inside to keep them out of the fenders.
   / Tractor tire chain spring tensioners #11
Ours are put on in the barn also but they have been known to come off in use, you can pull a chain off when you use the split brakes
Tom in Vermont
   / Tractor tire chain spring tensioners #12
Shine:
I have the tensioner tool also. I'd agree that it was a PITA the first time. The trick is to tighten the chains, drive ~100 ft. retighten and do again. i.e. 3x.
   / Tractor tire chain spring tensioners #13
My father worked for the local highway dept. They had 'double' chains across both rear wheels on 6 wheel dump trucks. They always used tensioners.
Two trucks were kept from October thru April loaded w/ salt or aggregate & plows mounted w/ chains on but parked on small wooden blocks so the chains were not 'flat spotted'...
Every night when snow was forcast, before going home, every department would chain up every dump truck & garbage truck. Highway had plows, Parks tossed snow shovels in the back [shovel all the city owned sidewalks] to get ready for the next morning...
Every set of chains had tensioners and they were used every time.
   / Tractor tire chain spring tensioners #14
...After a lot of thought on the matter, I decided to put chains on front tires only. I know a lot of people don't like that idea, but given the relatively light usage the tractor gets in the winter and the fact that almost all of my actual plowing is downhill, and more momentum driven than traction driven, I don't think it's going to put too much strain on the front drivetrain. I guess I'll find out though..
I used to think like you, but then I read about the possibility of the back breaking loose under braking and swinging around to the front of the direction of travel. The paved part of my drive that I plow has some pretty steep dropoffs to the sides of the pavement and I don't want to end up racing the tractor to the bottom with my frail old body.
   / Tractor tire chain spring tensioners #15
i can put the rear chains on my l4400 is about 15min/side, tensioners included. i use a 1" ratchet strap to install the 6 tensioner springs. not really rocket science, or an option as to not using them
I ended up takeing the tensioners apart and useing 3 chains with springs, eliminateing the ring in the center. Works OK but if I had it to do over would have just used bungies.
   / Tractor tire chain spring tensioners #17
One good bungy and make some S hooks from heavy wire or cut open some chain link singles..
   / Tractor tire chain spring tensioners #18
Sorry for a related tangent. I have cut down my old chains for my new tractor, works great, but have run into a clearance issue. A sheet metal seam on the inside of the fender is getting beat up by the chain attaching clasp.
The options I can think of:
Spacers on the rear wheels. (would work but also make the rig wider than my snowblower)
Let the chain beat the seam flat.(but the tractor is still shiny and new)
Loosen inside of chain, tighten outside, pulling the clamp out of range of the seam. (didn't work due to profiles of fender and tire)
Replace clasp with a 3/8 or 1/2 inch quick link.
This is where I pause and ask advice. The quick link would have a lower profile, but could be a bother to install, might break or loosen.
   / Tractor tire chain spring tensioners #19
Replace the clasp on the inside with just a simple hook. Adjust the length of the inside side chain so it is the correct length, and do all the take-up with the outside side chain.
If the chains are for this one tire, then they can be fitted to that tire, leaving only a couple extra links for take-up/adjustment on the outside side chain. Remove everything else. IMO :)
Well fitted chains need NO tensioners on the outside. They are just extra fluff, and to make up for ill-fitted chains for that tire size.
   / Tractor tire chain spring tensioners #20
Depends on where it's hitting, but by changing the length of that inner chain (by where you connect to it) you can either bring it down the inner sidewall away from the top of the tire, if that's where it was hitting, or bring it way up close to the top of the tire, if it was hitting the sides.
Do that of course with the outer chain loose, you should always set up the inner chain to the desired position first, having the outer chain connected but slack. Once you get the inner chain where you want then pull everything up tight with the outer chain, and tensioners if you use them.
Because all the slack is taken up with the outer chain you could use one of those lower profile threaded link things, I don't see any reason it would break, could always put a little tape on it to prevent it from loosening. But even if the threaded barrel loosened it would still be taught so I don't think it would come undone.
Threaded Replacement Chain Repair Link 10,000 lbs (6) - eBay (item 200425772730 end time Feb-06-10 11:41:20 PST)
JB.
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
2017 Ford F-650 Mason Dump Truck (A59230)
2017 Ford F-650...
VOLVO A25G OFF ROAD DUMP TRUCK (A60429)
VOLVO A25G OFF...
2018 Regal 29OBX 29ft Yacht with 34ft Trailer (A59231)
2018 Regal 29OBX...
2015 KOMATSU D155AX-8 CRAWLER DOZER (A60429)
2015 KOMATSU...
2016 VOLVO SD75B SMOOTH DRUM ROLLER (A60429)
2016 VOLVO SD75B...
