The smallest 4WD Bota gets heated hard cab
   / The smallest 4WD Bota gets heated hard cab #1
locknut
Kubota
Just finished her up and she's working good.At my age I don't like the open-air so much anymore :)
1-1/2" main frame
3/4" door and side panel frame
Skin-12 gauge steel
Aluminum roof panel
Laminated tinted glass windshield
Tinted Lexan side and rear windows
24V 700 watt heater
55 watt driving lights
LED tail lights
Remote controlled caution light
Automatic door closure w/Perko flush mount latch
Weighs around 300 lbs so it's a little top-heavy :(
Total investment around 2K when I get the 24V alt rigged up under the tractor and hooked to the mid PTO.
Pics;
Several more pics;
GR2000 Cab Project pictures by locknut-1 - Photobucket
Complete build thread on another forum but not sure if it's ok to link that :eek:
   / The smallest 4WD Bota gets heated hard cab #2
NICE!!! :cool:
Thanks for posting the pic...makes me want one...
   / The smallest 4WD Bota gets heated hard cab #3
I like it! That would be a handy little outfit, especially for tight places
   / The smallest 4WD Bota gets heated hard cab #4
Did you make the cab or was it purchased?
I designed it and farmed out the welding to a local fab shop.The build detail is on a thread at mtf* in the build it yourself section.I built it pretty tight as I'm heating with electric.The door goes"whoosh" when closed :)
   / The smallest 4WD Bota gets heated hard cab #6
Wow - super job Locknut. You have some awesome fabrication skills. I guess you're slowing building a 3/4 scale B3030. When does the backhoe go on. :D
   / The smallest 4WD Bota gets heated hard cab #7
Looks like a tractor only smaller..:D Just kidding. GREAT cab..
   / The smallest 4WD Bota gets heated hard cab #8
I need to add a door closer to my cab, and what you used looks to be perfect for my application. Where did you purchase it, and do you have the part number or description? I have a Curtis soft cab that I am going to be changing the doors to metal skinned and adding a sliding window to it. Thanks
   / The smallest 4WD Bota gets heated hard cab #9
Great Job! You must have the greatest and most expensive lawn tractor ever. Let us know if the top heavy bothers you when you use it more. Will the cab come off in the spring?;)
I picked it up at a local hardware True Value store.Had two choices;one for 15 or one for 20,so I got the HD $20 one.Should be an easy item to find at any hardware or home center store.
2020 MACK P164T (A58214)
2020 MACK P164T...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A55315)
2023 Unverferth...
2018 Chevrolet Equinox AWD SUV (A56859)
2018 Chevrolet...
2017 Ford F-550 Crew Cab Enclosed Service Truck w/ Liftgate (A56858)
2017 Ford F-550...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
2007 Hummer H3 4X4 SUV (A56859)
2007 Hummer H3 4X4...
