Plans for a small bridge?
   / Plans for a small bridge? #21
Where in Georgia are you? There is a pole plant at Sycamore in Turner County right along side I75.
   / Plans for a small bridge? #22
I sincerely appreciate all the help, folks.
Any ideas where to find poles like that in Georgia?
Where in Ga. are you located ? There are several places to buy new poles. The Power companies will usually give you old poles but beware they are either broken (cracked and no longer sound) or rotten. Some times you can find them in good shape but its a crap shoot.
I'm in Perry, GA. I actually called an electrician I do business with and he told me I could get the 25' temporary power poles new from Flint Energies for about $75 each. They ought to be perfect for this project. I'm in commercial construction and am about to demo a school starting this summer. I might try to get a couple of smaller beams from the school to use as support as well. That's a good idea.
In fact, there is another area on the land that I intend to build a bridge, but it is a much longer span. If I can score some longer steel beams that would be a great place for them.
   / Plans for a small bridge? #24
Heres the bridge I built on my property last fall. I made it out of used T-Bar joist I primed and painted.
Nice job, i need to span 33 feet, and get the tractor across w/ BH #7500
   / Plans for a small bridge? #25
Same boat here (haha) need to span a small creek on the property. Was thinking of digging out bunkers and laying 8 or so 12"+ logs from the property across, then decking.....any thoughts?
   / Plans for a small bridge? #26
Scroll back up a few posts and check out the "timber bridge" link. That link has some great info on what you are asking about.
   / Plans for a small bridge? #27
You need an engineer. That span is nothing to fool with. Takes some real material.
I always like steel. It doesn't rot in 10 years.......
--->Paul
   / Plans for a small bridge? #28
OK got it, that's exactly what I need. Now I just have to figure out log diameter X # of logs X span = weight bearing ability....?
   / Plans for a small bridge? #29
Years back I was looking at the equation for the deflection of a beam from a point load at some point on the beam. There were various constants that dealt with the material dimensions and type. What was interesting was there was a fifth power term in there that had the length of the beam. In computer code terms, it was a L ^ 5 or length to the fifth power.
So part of why it's so hard to apply common sense to spans is that this fifth power term puts it way outside of most of the things we see. As an example, when going from a 20' to a 25' span, the deflection at the midpoint goes up by a factor of 3 even though the length only went up by 25% or a fourth.
So I'm with rambler on this one.
Pete
   / Plans for a small bridge? #30
--->Paul
yes 2 w 12 beams 750lbs. each 750 dollars each, was thinking 40 foot flat bed trailer
2016 CATERPILLAR 304E2 EXCAVATOR (A52709)
2016 CATERPILLAR...
(2) UNUSED 460/85R30 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A55302)
2016 Ford F550 4x4...
White Metal Roof Panels (A55758)
White Metal Roof...
Enmark Z Spray (A53316)
Enmark Z Spray...
2007 Ford F750 (A55973)
2007 Ford F750...
