Can I modify my bandsaw's hydraulic cylinder?
   / Can I modify my bandsaw's hydraulic cylinder?
I modified the cylinder today and it works just as I want it too. The ball valve is just below the feed rate valve and the ball valve's handle is obscured by the valve body. The hardware only carried 45-degree flare fittings, so off to the Parker store to get a JIC fitting for the lower port. The hose is Parker's Push-Lock and it solved the problem of how to connect it all quite nicely.
Total parts outlay including ball valve was less than $20. That beats the ~$200 that Jet and Grizzly wanted for replacement cylinders.
   / Can I modify my bandsaw's hydraulic cylinder? #12
Nicely done!
2014 Toro Workman HD 07369 Utility Cart (A51691)
2014 Toro Workman...
2018 FORD TRANSIT T150 CARGO VAN (A54313)
2018 FORD TRANSIT...
2011 New Holland B95B Cab MFWD Loader Backhoe (A53473)
2011 New Holland...
17101 (A53421)
17101 (A53421)
King Kutter TG72 Rotary Tiller Tractor Attachment (A51691)
King Kutter TG72...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A54607)
PEMBERTON...
