Bird
Rest in Peace
Wow! Sounds like quite a project. I don't know anything that would help you, but I sure wish you luck with it.
Hi Rox, like Bird said "quite a project". I will be watching with interest.
A couple of thoughts as I read your plan. I think of containers as being engineered in a way that the walls and ceiling all contribute to the structural integrity of the unit. A bit like an enclosed trailer used behind semi trucks. As a unit they are very strong but if you remove the walls they are not strong at all. I would consult with the container company and ask their opinion on how the openings you plan to cut and concrete floor system will effect the containers strength when moved in the future.
I was also wondering if you have a public sewage system or a private septic system? If you are on a septic will the residue oil and added load affect the system? Also, is it all right to add commercial waste to the public system if that is what you are on?
MarkV
Maybe a sloped floor where debris goes to one side and drops into a channel drain might work. To me, this is one of the most difficult design features, to get the floor debris to clear and not have to add tons and tons of concrete to the floor just to be able to create a drain system. It seems a slanted floor with a runoff into a channel drain at the walls could be a possible solution.
Finally, electricity in this environment would/will be a constant hazard. Everything around you is going to be a conducter. I'm sure there are codes there that require strict safety features. This portable olive mill inside a container will present some unique challenges to meet codes. Bringing in an expert early in this process is needed.
These are just some random thoughts of mine. I love your can-do spirit towards getting this built and into operation. I hope I've helped a little bit.![]()
I have been thinking about the waste water problem. You will not have any gravity drain or not much. How about draing it into a small pump chamber, like a sump pump. runs off a float. Pump it into a farm tank on wheels. When it is full hook up the tractor and tow it to the fields. Have to do something while the tank on wheels is away. Pump it to a small stationary tank or stop work till the rolling tank comes back. This is like wine, pump it antwhere you want.
