Where is Eddie Walker when you need him? Totally MIA from this thread and he already built a contianer cabin... sheesh...
Hi Rox.
I just found the thread.
I'm on my third container right now. As you remember, I had two that I put a roof over to create a barn, and then made an apartement off to one side of one of the containers. The one I have now is just for storage, but I'm planning on adding on to it for more storage.
I'm a big fan of containers for the simple reason that you get an instant building that is very secure for a fair price. I don't know the conversion, but it doesn't really matter. You said that you are paying 3,600 euro for your container. The container is 8ft wide and 40ft long, for 320 sq ft. That's 11.25 euro per square foot.
You've mentioned several times how expensive it will be to have a building built, but the difference in price has me wondering if you are comparing apples to apples? You are more then capable of being a General Contractor. Have you broken down each part of building it yourself? To build a shell of a building, which is all that you need, is very simple.
Utilities are a given either way you go. So that figure is set. You need sewer, water and power. Running a sewer line up and into the container is going to be an issue that I'm unsure of how you will accomplish this. There will have to be some tunneling and cutting through the floor. In my containers, the floor was hardwood, but I don't know what's under the wood, or what it takes to get through it. Then building up the floor for the dain can be as simple as pouring a leveling compound, using thinset or something else. The expense to do this isn't going to come close to what a concrete slab will cost, but the slab will be permanent and have the slope with a great big drain built into it. In my experience, that alone is worth whatever it costs.
I don't know what it takes to make olive oil or work the machine, but my fear is that with a very small space to work, you might not be able to do the best possible job. With enough space and a workable layout, you will be more effective and probably produce a better product. The container limits you to such a degree that I question whether it's even practical.
With a concrete slab in place, you can either build a barn or set up a temporary tent. I really like the idea of a tent for now. They are very common here for wedding and events. They can be heated and even cooled. They set up in a day and some will remain for weeks at a time. You could set the mill up on wheels, so it can go from the garage to the slab when you are working, and when you are done, it can be all taken down. If this is feasable, I'd seriously consider it before modifing a container, to only find out it's too small to get anything done.
If the tent idea isn't practical, what about a greenhouse? Here, they build them from pipe and cover them with plastic or a tarp like material. You can buy a kit, or piece it together yourself. I know a guy who build one from PVC pipe that he glued together. A few times a year, I get a catalog from a company that sells the kits to do this. It's a cheap way to get a dry space. Not all of them are greenhouses, but are more barnlike in their purpose. The catalog is all mail order, but I don't know if they ship international.
Looking at your pictures, I'm wondering if you could add on to your garage? What would it take to build three walls and a roof in front of one of the roll up doors? I there a slab or concrete in place? Could you take off the roll up door and re-use it if you added on there? I would make that part of the plan if it was me.
Consider that you are willing to try and make a container that is 8ft wide work for a building for your mill. If you had four more feet, for 12 feet of space, how much better would that be? A shed or building that is 12 feet wide doesn't take any skill to put a roof on. It's easy to just lay 2x6's across the top of the walls and then cut and install two more for the pitch of the roof. This is the most simple type of truss and one that will easily span 12 ft. Every roof is a triangle. For small buildings, that's all you need. If you went 16 ft, you'd have to add a bit more to it for the truss to work, but it's still something that's easily enough. Then it's just a matter of what type of roof you want.
Before committing to the container, break down what it would cost to build a building that's big enough to do the job. You've said that labor is fairly cheap, but materials are expensive. My question is to what detail did you price the materials? There isn't very much in materials to building a small barn.
As you can see, I'm not for the container option. Not even as a last resort. They are excellent for storage, but terrible to work in. The modifications that you want to do to it will cost allot, and even when it's fully modified for your needs, it's still a very small space. Planning for just using it for three years and then building what you want is always a good idea, but in my experience, it never works out that way. There are so many things that change, it's hard to know what you will need, or where you'll need it in three years. If the mill proves to be profitable, will you want to build a new building, or invest in other aspects of milling olives? It's like the guys who want to build a barn and add living quarters to it while they are building their homes. Everybody expects to be there a year or two, but allot end up living there for allot longer. It's too hard to predict the future and trying to plan for it will sometimes just mean throughing money away on something that you will never need. Wheels and moving the container around after you have modified it to your needs sounds like good planning, but it also sounds like a way to spend money that you may never actualy get any return on.
Hope this makes sence, I sort of rambled on.... LOL
Eddie
