Shocks for my 2005 Dodge 3500 4WD SRW
   / Shocks for my 2005 Dodge 3500 4WD SRW #1
ddivinia
Elite Member
Red Oak, Texas
JD 5525 and 5093e Kubota SVL75
I have a 2005 Dodge 3500 Quad Cab 4wd short bed SRW. I have 80K miles on it and the shocks are starting to feel soft.
I don't have a suspension lift, but I do have bigger tires (315s - H2 tires).
What shocks should I put on it?
Thanks
Darin
   / Shocks for my 2005 Dodge 3500 4WD SRW #2
Bilstein's seem to be the best thing going for the heavier trucks. Cost a bit more but hold up better.
I have been looking at Bilstein and Rancho.
D.
   / Shocks for my 2005 Dodge 3500 4WD SRW #4
The best choice is the bilstiens in the HD version. I've heard nothing but 100% positive about them for hd truck applications. Just make sure you get the yellow hd ones and not the 5100's those are more for sporty handling than hd work. There's an online retailer that runs a special where you buy three get one free. Check it out.;)
Matt
   / Shocks for my 2005 Dodge 3500 4WD SRW #5
I second the Bilstiens. I put them on my CC diesel at 30K miles. Made an incredible difference in ride handling and stability over the stock shocks. I have 70K on the truck now. I will be doing another set of bilstiens when I do the leveling kit.
Also have heard good things about Ranchos, but I do not have any experience with them.
-Keith
   / Shocks for my 2005 Dodge 3500 4WD SRW #6
On my F350 It cam with Rancho's and they were good shocks, when I changed them I too added larger tires---LT 305's and at that time I installed the HD Bilsteins, I tow an RV that weighs in around 12,000 lbs. They do seem to handle evrything much better.
DevilDog
DevilDog
Which Ranchos did you have and which Bilstein did you go to?
D.
4 wheel store has their super shocking deal page:
Shocking Deals
Bilstein 4600s for $249.99
Lots of different models of each brand.
I might have to go by the local 4 wheel parts store and talk to them.
D.
   / Shocks for my 2005 Dodge 3500 4WD SRW #9
There's two shock's that do well on the Dodges. One is the Bilstein HD's (blue/ywllow), and the other is the 5100's (silver/black). The HD's are only for stock lift and suspension, and I believe the 5100's will work with a stock suspension up to a 2" lift on the front end. The 5100's are the better shock IMO. Dodge Cummins Diesel Truck Accessories Geno痴 Garage sells both of those shocks, and the 5100's are only about $5 more.
Good info - THanks, D.
2017 John Deere Gator TS Utility Cart (A50324)
2017 John Deere...
2018 Freightliner M2 106 Rollback Truck (A50323)
2018 Freightliner...
UNUSED PALADIN SKID STEER HYDRAULIC BREAKING HAMMER (A51243)
UNUSED PALADIN...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
16FT Flatbed Trailer (A51573)
16FT Flatbed...
McDon 75s 40' Flex Draper Head (A52349)
McDon 75s 40' Flex...
