attachment question
   / attachment question #11
I agree the abilty to adjust fork widths is a handy option to have and probably a more popular feature than weight carrying requirements.
So far, on my 3 point Carry-all, all I've hauled is fire wood, either on pallets, or wood racks that I've made. In pallet form it's about 750 - 800 pounds.
I'd like to be able to haul this with forks on the front loader too.
The weight limit for items in my bucket about 800 pounds (I've got a LA402 Loader)
I'm affraid bucket forks, extending my load further away from the loader pins, would over extend the loaders recommended weight capacity.
The carry-all, as a loader attachment, would keep my load closer to the loader pins, giving the advantage to carry more payload. Which would work good for me.
   / attachment question #12
I mounted a "carry-all" type of forks on a FEL and it didn't place the load any closer to the pins than a set of clamp on forks do. Not sure how you would mount it any closer unless the tractor has the QA bucket system.
BTW, the LA402 loader has a capacity of double the number plus another 10% (or multiply by 2.2). But who's counting.:)
   / attachment question #13
Yes it would be a pin type QA bucket system, and I failed to have mentioned QA bucket system.
I did mention, using a carry-all as a loader attachment,
but I should have clarified that I'd remove the QA bucket and attach the newly modified
QA carry-all. I appoligize by getting ahead of myself.
Yes I've heard about doubling the loader number, as a rough guide to calculate lift capacity, I hadn't heard about adding an additional 10%.
I was estimating about 800 pounds lift capacity, by your guidelines it would be 884.4 pounds ?
My concern would be the 800 pound load thats on bucket forks, is out beyond the measurement point for the 800 or 884 pound.
   / attachment question #14
I've got a QA on my FEL and I bought an attachment that connects to my QA then attaches 3 pt implements. I use it primarily to mount my carryall on the front. -- My vote goes to a set of forks vs a carryall.
   / attachment question #15
The FEL number (LA402) idicates the lifting weight in kg. To convert it to pounds the multiplier 2.2 will do it. Mathematically it is the same as times 2 plus another 10%. Close enough.
The maximum load capacity is at the top of the lift so the reality is that to get a weight off of the ground it is probably quite a bit more. The tractor's relief valve will keep serious damage from occurring.
With a carry-all mounted to a QA plate it would act just like a standard factory QA fork lift. The lifting ability would be the same as the bucket - probably a bit more since the fork contraption would weigh less than the bucket.
The QA frames are quite reasonable at auctions. This one was purchased at Ritchie Bros. Auctions and a log carrier built on it. They have actions all over the world. An auction yard is only 20 miles away from my place. Maybe you can find something similar.
   / attachment question #16
Gwdixon,
Love the forks! I am going to try to make some for myself some time before spring.
Savageactor7,
I have same issue when I go out for wood, where to put tools and still be able to use bucket. I was thinking of doing something simular, but I was concerned about raising and lowering the 3pt .... how do you keep the wood from buckling?
   / attachment question #17
I have a 3point carryall & haven't used it for years. I used it alot back in the day when it was all you had to lift something, not very high but better than nothing. Once you get a loader, the carryall day is done!! It's good to put a pallet on & carry things around like you would do with a Gator or something but if you already have a loader, you probaly want the forks.
   / attachment question #18
The cheapest frame and fork combination I've seen around here is about $500 used,
for a Skid Steer, and its heavy, and I 'd have to get it adapted to the Kubota Pin QA.
The new Kubota Pallet frame, for the Kubota Pin QA, is $544.00 at 145 pounds,
and the 36" pallet forks are $350.00 at 154 pounds.
Total $894.00 at 299 pounds. These are 6 year old suggested retail prices.
So with time and fluctuating steel prices, actual cost maybe differant now.
This is the Frame /Fork combination Kubota builds for the B7800 tractor with Pin QA.
I would think aftermarket frame/forks could be cheaper,
but probably about the same in weight.
The Carry-All is about $135 includeing tax at Tractor Supply,
and I'd have to adapt it to the Kubota Pin Qa also, less than $50.0O for me.
The Carry-All is rated to carry 1000 pounds and it weights only 75 pounds,
and maybe it would weigh 100 pounds after QA adapters are added.
I would be able to carry 199 pound more in payload by using the
Carry-all Qa compared to the Kubota frame/fork QA.
For me, payload is a bigger concern than adjustable forks.
I have been hauling my 16" firewood from the woods on
pallets/wood racks on my 3 point carry-all,
with a homemade rack on the front,
carrying buckets of sand for front end ballast.
Now that I have a loader with pin QA,
my plan was to use the Carry-all QA attachment to also haul firewood.
The wood on my 3 point carry-all would be ballast for the loader QA carry-all loaded with wood.
I know of another B7800 owner that uses 800 pound 3 point ballast with no problem.
I just got to make sure that I load the loader QA carry-all last and unload it first,
to insure my rear tires don't come off the ground.
   / attachment question #19
Sounds like you have a good plan. Go for it.
My only issue is that fooling with the bucket and carry-all by taking it on and off could be discouraging to its use.
The channel iron, clamp-on, forks can be put together for less than $100 total. They weigh about 20 pounds each. They might be worth a try first to see if they will do the job before going into a full-blown project to adapt a carry-all to your QA.
The clamp-on forks can always be used for other projects if lifting cordwood at the extended distance is a problem. I don't think it would be given that a 1/4 cord of wood doesn't weigh enough to keep the lift from getting at least a foot off of the ground. Remember, the FEL weight rating is to the very top of the lift.
BTW, the frame used for the log lifter was $200 new. The last one of the eight at the auction went for $100. There are also the QA flat plates to be welded to whatever for $50-$100 new. They are the skid steer type so wouldn't do you much good.
   / attachment question #20
I have TSC carry-all that I never use anymore as I find I like having the box blade on the back as a counter-weight and for trail maintenance.
My $1000 Tatro bucket grapple/WR Long electric valve kit has worked out to be the perfect front end tool along with my tooth bar. I thought about getting the Payne forks with logging attachments but the grapple is better for my applications-logs and rocks
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2015 Freightliner Derrick Diger Truck (A55973)
2015 Freightliner...
Enmark Z Spray (A53316)
Enmark Z Spray...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
