Can a 1533 handle a 60" tiller?
   / Can a 1533 handle a 60" tiller? #1
Specop_007
Nebraska
Pretty much like the title says. Thinking of a 1533, how well would it handle a 60" tiller. Seems to be on the real low end of power for a tiller this size and a 48" wont come close to covering the wheel tracks.
Thinking of pairing it with a King Kutter II, hence the 48 and 60" widths.
   / Can a 1533 handle a 60" tiller? #2
Our 1523 handled a 47" Kubota turfbuster with no problems, so I do not see why yours would not habdle that.
Hope others will chime in here.
   / Can a 1533 handle a 60" tiller? #3
Yes it should handle a 5' tiller with ease. I ran a 5' KK behind a Kubota L2050 25hp.quite a bit smaller tractor and less hp. Just had to go a little slower but could till the ground to powder if I did'nt watch.
   / Can a 1533 handle a 60" tiller? #4
I have a 1533 and it handles a 5' KK easily and just covers the tire tracks. If you have new ground that hasn't been worked for a long time you will have to take your time, mainly beacuse the tiller will bounce around. I usually like to plow new ground and then till it up after it sits for about a month.
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
Gradall 53409-45 Telehandler, Turbo Diesel Engine, 45' Reach, Rear Steer, 60" Forks, 6,699 Hours (A59076)
Gradall 53409-45...
VICOR HAY CUTTER (A58214)
VICOR HAY CUTTER...
2012 Toyota Camry Sedan (A56859)
2012 Toyota Camry...
12V 20GPM Gasoline Fuel Transfer Pump (New/Unused) (A59225)
12V 20GPM Gasoline...
2020 DRAGON ESP...
