Thanks for the mention, Here is the ballast I made for my tractor. I put 800 lbs of cement and rebar in a 55 gallon drum. I am sure you can put a 1000 lbs in it. I have a nice lid on the drum so the cement is about 8 inches from the top. I keep it full of chain and cable slings. The 1 think I would do different is I would set the rod at a hight close enough that the drum could have added support from the draw bar rather than relying on the 3 point lift arms. I am sure it would never be a problem but the draw bar is right there. I have no problem plowing snow or stability with forks. The drum fits in tight between the wheels. I usually have a box blade on using the loader because they are companion pieces but for any heavy lifting and moving at speed with a load I use the drum for stability. I am not a fan of loaded tires personally. There are time I want the tractor very lite for field cutting and work in the woods when I want a soft foot print. I should also mention that because of where the rod goes through the drum at just above center I have no need to use a top link. If you watch the snow plow link you can see it doesn't move at all. This is the best ballast I have for its size and shape. By the way the snow I am moving in the video is the same storm you are talking about in the original post
