dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,662
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
I find it hard to beleive that a JD 770 does not have some type of internal overrun clutch for the PTO to prevent that from happening.
Even my older 1978 JD 850 with single stage clutch and non-live PTO has an overrun clutch so a brush mower doesn't drive through the PTO pushing the tractor.
My B21 and my JD4300 were both HST units with no overrun clutches in the
the PTO drive train. The former had a simple one-stage dry foot clutch
that disconnected the engine from the drivetrain, mostly for PTO control.
The second eliminated the foot clutch entirely so another method had to
be used to engage the PTO. This is a trend in CUTs that we will see more
and more, and the makers are experimenting with a number of different
approaches. On the 4300, the PTO control is a fragile hand lever-controlled
wet clutch that is either all on or all off, and a wet clutch brake is used on
the same shaft. How many CUTs use PTO brakes? All the momentum of
a rotary mower being braked tended to break the brakes.
Another trend is the use of quieter helically cut gears in the range shift,
gearboxes, versus straight-cut gears.
Back to the OP's MF35.....the one I drove with the torque converter ran
its implement pump off the gearbox, not directly off the engine. This meant
that you have to rev up the engine a bit just to get the hyd pump to work.
