Delo 400LE vs Tractor Supply House Brand
   / Delo 400LE vs Tractor Supply House Brand #1
UncleBuck01
NY
Mahindra 4110
Asked wife to stop at Tractor Supply when she went shopping this past weekend, asked her to p/u 3gals. of DELO 400LE CJ/4 diesel engine oil which is on sale for $10 a gal. She came back with Traveller all fleet diesel engine oil 15W-40 CI/4 which was on clearance $4.99 a gal. What Would You Do, use it for spring oil change in my tractor, a Mahindra 2002 4110 with 800+ hrs or go get the DELO oil which is still on sale.
Do something special for your wife... It looks like she just saved you 5 $ a gallon = $15... KennyV
I did, I married her 29 years ago,
just kidding :D , So I'm guessing you would use it for the spring maintenance
   / Delo 400LE vs Tractor Supply House Brand #4
Sure... They are both good quality 15W40 diesel rated motor oils... That is what you have been using.
Myself, I use synthetic but I don't think you can go wrong using good multi-viscosity non-synthetics. KennyV
   / Delo 400LE vs Tractor Supply House Brand #5
BTW...
There are a lot of oil folks that will tell you to get all the CI-4 oil you can as it is a superior formulation to CJ-4... But do not use CI-4 in a on highway diesel with an exhaust aftertreatment device such as diesel particulate filter (DPF) or diesel oxidation catalysts.
You will not be able to find CI-4 after the existing stock is sold out. There was a big run on it here about a year ago and it disappeared quick. KennyV
BTW...
Ken
Does oil have a shelf life, at that price should I go buy whats left at the store
   / Delo 400LE vs Tractor Supply House Brand #7
That is an arguable question.. everything has a shelf life, but a lot of things have such a long life expectancy that it is not normally considered...
I would not be concerned with having several years oil supply on hand, if it were available at a good price.
That said, you and everyone else will eventually have to switch to the latest blends--- at some point. KennyV
   / Delo 400LE vs Tractor Supply House Brand #8
I sure hope it lasts a long time - I scarfed up about 40 gallons of RTS 5-40 CI-4+ last year. ;)
   / Delo 400LE vs Tractor Supply House Brand #10
I bought Rotella around 2004 in gallon jugs for $3 per gallon that was on clearance due to it being the old white bottles. I am down to my last 3 gallons and only run it in my tractor. It has the foil covers under the cap so yes it may have a shelf life but I am sure it would last for 10 years or more if in sealed containers.
Chris
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2017 Ford F-550 Bucket Truck - 4x4, Powerstroke Diesel, Versalift VST47, 52FT Reach (A52128)
2017 Ford F-550...
(INOP) CATERPILLAR 259D SKID STEER (A50459)
(INOP) CATERPILLAR...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
2017 DODGE RAM 5500 HEAVY DUTY SERVICE TRUCK (A51243)
2017 DODGE RAM...
John Deere Quick Attach Bale Spear (A50514)
John Deere Quick...
