Compressed Air Piping
   / Compressed Air Piping #31
My brother uses PVC in his garage for air, has for years with little or no problems.
   / Compressed Air Piping #33
I ran pex through out my shop and even 3 runs from the barn back to the house for a fitting in a closet upstairs, down stairs, and in the garage. Been that way since 2004 with no issues at 150 psi.
Chris
   / Compressed Air Piping #34
I also plumbed my (125 PSI) shop air with schedule 40 PVC nearly 20 years ago. I too have a short length of rubber air hose between the compressor and the pipe. The number one issue with PVC is the derating when it gets too hot, and the section of hose does help limit that. Ignorance is, after all, bliss.
I suspect that by now, I would have had more problems with galvanized pipe rusting through.
Oddly enough, it's the PVC water line that burst one winter when we had sub-freezing weather for about two weeks (I live in Florida). I went out to my shop and heard a hissing sound as I approached the door. When I opened it, I was greeted by a beautiful winter wonderland display covering almost everything inside. The pipe had split just the right way to create a very fine fan of water aimed perfectly to cover at least 500 square feet or so. I had to drill a hole through the back wall (and sleeve it with copper pipe) to let the water drain out.
I fixed it and put one piece of pipe insulation on it, and have not had any freezing problems since.
And just this weekend my son returned from our "gazebo" on the lake with the water filter parts in his hand. The top looked like it exploded when it froze. I guess it got cold in the little bathroom a few weeks ago...
So far, freezing is worse to me than compressed air when using PVC.
Regards,
- Just Gary
   / Compressed Air Piping #36
The Harbor Freight kit would be very hard to beat, BUT, it is probably China built. If you put it where it can be accessed if problems happen, you would be better off.
   / Compressed Air Piping #37
Regards,
- Just Gary
It all depends on how lucky you are. Not every PVC airline installation fails. If they did, we probably would not be having this discussion. I just don't want to be around when the random catastrophic failure does happen. And it will not happen in my shop.
   / Compressed Air Piping #38
The jury has decided, and the case is closed. PVC for air has been proven to be unsafe. People have been injured, and it has been banned for such use, by everyone who regulates it.
Any anecdotal evidence to the contrary, does not prove otherwise.
Anyone who uses it, is playing Russian roulette. Which, by the same logic is also safe, if the gun does not go off.
   / Compressed Air Piping #39
They way I see it, if you feel comfortable with PVC go for it. I think we are all aware of the danger. Some of us dont wear seatbelts, smoke cigarettes, and eat cheeseburgers from McDondalds. It's all a matter of what you feel safe with.
   / Compressed Air Piping #40
I 'd like to Thank those types of people for providing me with job security.
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2011 FORD F-450 (A52472)
2011 FORD F-450...
2016 Chevrolet Malibu Sedan (A51694)
2016 Chevrolet...
2005 FREIGHTLINER COLUMBIA SLEEPER (A54313)
2005 FREIGHTLINER...
2000 International Log Truck, Triaxle, Log Bunks (A52384)
2000 International...
