Hello, everyone!!
   / Hello, everyone!!
Yes, it is a manual trasmission. The filter is a screen and bolt that goes through the suction tube . I'm wondering if the sae 80-90 is too thick w/lower temps. (40 F. yesterday/ average) Was working fine before draining and refilling.Will start again after COFFEE!
   / Hello, everyone!! #12
Just operate the 3PH lever over several minutes for the first attempt at a fix. Hopefully, that will expel the air from the lines and cylinders.
   / Hello, everyone!!
Gentlemen,
:) All is well! A couple of hours ago, I was really cussing The Orange Machine!:mad: The filter is a machined Hollow Bolt that passes through the suction tube. (25 mm) Aprox. 8" long, except the inner 6" is a spring with a very fine screen surrounding it. (Bad Design!!) After pulling the bolt, which I'm sure has never been done (1,100 Hrs.) the tube itself shifted backwards! Finally after 2 hours , managed to shim, block and pry back to position in order not to cross thread.(after pulling rear wheel, should have done 1st) The screen was 98% blocked. (Took pics) Anyhow, 3PH lifts like never before and without the whine @ the top end!! Thanks to everyone with their input and mostly quick response! I found a better Forum!! Steve.:cool:
   / Hello, everyone!! #14
Wow! A good news story at last. They seem to be few and far between.
But this is a forum for solving problems so a lot of troubles are presented here.
   / Hello, everyone!!
Thank You for the help, gwdixon!!;) and Randall and Everyone!
   / Hello, everyone!! #17
I have a 79 B7100D and the manual calls for 80w-90 oil. That was changed quite a while ago to UDT.
If you call a dealer they should know that.
KMC 70Z7 WHEEL LOADER (A52709)
KMC 70Z7 WHEEL...
UNKNOWN  SKIDDED FRAC TANK (A58214)
UNKNOWN SKIDDED...
2008 Hino 268 Truck, VIN # 5PVNJ8JV582S51513 (A57453)
2008 Hino 268...
Kubota R5205 (A57148)
5'x8' Rubber Mats (A55272)
5'x8' Rubber Mats...
Giyi 66" Rock Bucket (A57149)
Giyi 66" Rock...
