Hello, everyone!!
   / Hello, everyone!!
Yes, it is a manual trasmission. The filter is a screen and bolt that goes through the suction tube . I'm wondering if the sae 80-90 is too thick w/lower temps. (40 F. yesterday/ average) Was working fine before draining and refilling.Will start again after COFFEE!
   / Hello, everyone!! #12
Just operate the 3PH lever over several minutes for the first attempt at a fix. Hopefully, that will expel the air from the lines and cylinders.
   / Hello, everyone!!
Gentlemen,
:) All is well! A couple of hours ago, I was really cussing The Orange Machine!:mad: The filter is a machined Hollow Bolt that passes through the suction tube. (25 mm) Aprox. 8" long, except the inner 6" is a spring with a very fine screen surrounding it. (Bad Design!!) After pulling the bolt, which I'm sure has never been done (1,100 Hrs.) the tube itself shifted backwards! Finally after 2 hours , managed to shim, block and pry back to position in order not to cross thread.(after pulling rear wheel, should have done 1st) The screen was 98% blocked. (Took pics) Anyhow, 3PH lifts like never before and without the whine @ the top end!! Thanks to everyone with their input and mostly quick response! I found a better Forum!! Steve.:cool:
   / Hello, everyone!! #14
Wow! A good news story at last. They seem to be few and far between.
But this is a forum for solving problems so a lot of troubles are presented here.
   / Hello, everyone!!
Thank You for the help, gwdixon!!;) and Randall and Everyone!
   / Hello, everyone!! #17
I have a 79 B7100D and the manual calls for 80w-90 oil. That was changed quite a while ago to UDT.
If you call a dealer they should know that.
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
2004 Ford Explorer Sport Trac Pickup Truck (A56858)
2004 Ford Explorer...
Dewalt 14" Chop Saw (A59076)
Dewalt 14" Chop...
John Deere 1025R (A53317)
John Deere 1025R...
(2) TRUCK TOOL BOXES (A58374)
(2) TRUCK TOOL...
2004 Freightliner FL60 Ambulance (A56858)
2004 Freightliner...
