Ford 1320...enough HP?
   / Ford 1320...enough HP? #1
tydp
Tyler, TX
Ford 4100, Kubota M5400, Kubota M9540
I've never owned a SCUT. I MAY buy one to do some finish mowing. Does a Ford 1320 (20 HP, 17 PTO) have enough HP to run a 5' finish mower (3 pt connected)? Thanks in advance...
   / Ford 1320...enough HP? #2
My first tractor was a 1300 with a 5' Bushhog finish mower and it did just fine.
   / Ford 1320...enough HP? #4
I had a 4' rotary mower on my previous 19hp tractor. It struggled with it, even in moderate grass. In thick stuff it was a real chore.
Unless you keep your grass well trimmed, I would be cautious about going with that big a mower on that little HP. A finish mower is different than a rotary mower, but I would still want more power. Especially since you want a clean cut; you need those blades spinning...
   / Ford 1320...enough HP? #5
Apparently, more than a few 54" models are sold, which might be just right size? Do you already own the 60" finish mower?
No. I just wanted a 5ft. If all I can run is a 4ft, I'll just keep looking. Had a line on a very clean, low hour 1320 for a good price....
   / Ford 1320...enough HP? #7
it will run it with no problem; had one in 1998. You may have to drop down to lower ground speed in really heavy stuff, but it will handle it.
   / Ford 1320...enough HP? #8
Any idea what the recommended HP is per foot on a finish mower? I know the rule of thumb for a rotary is 5hp/ft on the PTO. My 19hp tractor with 16hp PTO sure struggled with the 4' rotary. It bogged easily, even with sharp blades, and low speed(low range on the 3-range HST). The tractor certainly did the work, for a number of years, but it was agonizingly slow if the grass got thick(field grass).
   / Ford 1320...enough HP? #9
I have heard between 3.5 to 5 pto Hp per foot of rotary cutter. Saying that, and everyone has different experience. Condition of tractor, right rpm has certainly directly relates to the engine HP achieved. I can brush hog 2 foot high stuff at about 1800-2100 rpm with no issue. My tractor is rated to have 23.5 hp at rated rpm of 2500, so I really don't know what hp I have at 2000 unless I have the power curve for my engine. What I'm sure is that I'm getting less than 23 hp and tractor seems to be doing okay. If I did taller and thicker stuff then my tractor squeals like a pig at the rated rpm with the same 5 foot cutter.
JC,
ps. same rpm and two exact tractors and no telling if hp output is exactly the same. Amount of compression and valve blow by might be different.
   / Ford 1320...enough HP? #10
I have a 1210 Ford and I run a 5 ft finish mower and it handles it well although I did have to put weight on the front end.
1996 Elgin Pelican Series S Street Sweeper (A55787)
1996 Elgin Pelican...
2021 CATERPILLAR 926M WHEEL LOADER (A52705)
2021 CATERPILLAR...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
TAKEUCHI TB250-2 EXCAVATOR (A52705)
TAKEUCHI TB250-2...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
