Ford 1320...enough HP?
   / Ford 1320...enough HP? #1
tydp
Tyler, TX
Ford 4100, Kubota M5400, Kubota M9540
I've never owned a SCUT. I MAY buy one to do some finish mowing. Does a Ford 1320 (20 HP, 17 PTO) have enough HP to run a 5' finish mower (3 pt connected)? Thanks in advance...
   / Ford 1320...enough HP? #2
My first tractor was a 1300 with a 5' Bushhog finish mower and it did just fine.
   / Ford 1320...enough HP? #4
I had a 4' rotary mower on my previous 19hp tractor. It struggled with it, even in moderate grass. In thick stuff it was a real chore.
Unless you keep your grass well trimmed, I would be cautious about going with that big a mower on that little HP. A finish mower is different than a rotary mower, but I would still want more power. Especially since you want a clean cut; you need those blades spinning...
   / Ford 1320...enough HP? #5
Apparently, more than a few 54" models are sold, which might be just right size? Do you already own the 60" finish mower?
No. I just wanted a 5ft. If all I can run is a 4ft, I'll just keep looking. Had a line on a very clean, low hour 1320 for a good price....
   / Ford 1320...enough HP? #7
it will run it with no problem; had one in 1998. You may have to drop down to lower ground speed in really heavy stuff, but it will handle it.
   / Ford 1320...enough HP? #8
Any idea what the recommended HP is per foot on a finish mower? I know the rule of thumb for a rotary is 5hp/ft on the PTO. My 19hp tractor with 16hp PTO sure struggled with the 4' rotary. It bogged easily, even with sharp blades, and low speed(low range on the 3-range HST). The tractor certainly did the work, for a number of years, but it was agonizingly slow if the grass got thick(field grass).
   / Ford 1320...enough HP? #9
I have heard between 3.5 to 5 pto Hp per foot of rotary cutter. Saying that, and everyone has different experience. Condition of tractor, right rpm has certainly directly relates to the engine HP achieved. I can brush hog 2 foot high stuff at about 1800-2100 rpm with no issue. My tractor is rated to have 23.5 hp at rated rpm of 2500, so I really don't know what hp I have at 2000 unless I have the power curve for my engine. What I'm sure is that I'm getting less than 23 hp and tractor seems to be doing okay. If I did taller and thicker stuff then my tractor squeals like a pig at the rated rpm with the same 5 foot cutter.
JC,
ps. same rpm and two exact tractors and no telling if hp output is exactly the same. Amount of compression and valve blow by might be different.
   / Ford 1320...enough HP? #10
I have a 1210 Ford and I run a 5 ft finish mower and it handles it well although I did have to put weight on the front end.
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
2014 Jacobsen AR3 Commercial Mower (A53421)
2014 Jacobsen AR3...
2013 International TerraStar Enclosed Service Truck with Liftgate (A55788)
2013 International...
PENDING SELLER CONFIRMATIONS (A56138)
PENDING SELLER...
2016 Ford Escape SE SUV (A55853)
2016 Ford Escape...
