Backhoe JD 300-D backhoe not movin...
   / JD 300-D backhoe not movin... #1
boomer7b
have a early 90s jd 300d, starts and runs but will not move, the shaft moves forward and reverse, into the rearend but will not move any help would be greatly appreciated. brian
   / JD 300-D backhoe not movin... #2
Welcome to TBN:D
Can't help with your problem...other than giving your post a little bump up to the top;)
   / JD 300-D backhoe not movin... #3
It sounds like you will need to tear in to the rear end :(
   / JD 300-D backhoe not movin... #4
Which shaft is moving? Do you have the transmission opened up to see shafts? You could have differential problem or one of the stub shafts connecting differential to the axle housing could be sheared off.
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
2014 F-150 STX (A56435)
2014 F-150 STX...
MONTANA MOUNTAINEER 5TH WHEEL CAMPER (A52708)
MONTANA...
Carry-On 6'x8' Trailer (A53316)
Carry-On 6'x8'...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A56436)
2021 Unverferth...
1985 Allmand Max Lite III LD30-3CE S/A Towable Light Tower (A55973)
1985 Allmand Max...
