OP
tomfifield
Thanks all; I got it running today. I drained the water from the tank and lines untill it ran clean and red. I have a L3400 and it has a valve you open to bleed the air from the pump. I did add some Diesel dry just to be sure. After a bit of smoke it cleaned up and ran fine. I use oil for heat in my house and have three 275 gallon tanks so I plan to make one a fuel tank. I will put a filter system like LBrown59 has on it. But in the short run that Mr. Funnel sounds like a good thing.
