patrick_g
Elite Member
My understanding is a partial tank of fuel (either can or on tractor) will have a higher propensity to have water condense inside it than a tank that is full???
I don't know that to be true, just something I once read. If accurate then it might benefit you to try to keep your tank(s) as full as possible.
A partially full tank breathes with changes in temp and air pressure. The air going into the tank can carry moisture into the tank. Then at night or when cooler temps come the water condenses on the cool tank sides as dew (water) and this action repeats over and over so substantial quantities of water can end up inside your tank (storage tank, jerry cans, vehicle fuel tank, or ...
A full container has little or no room for moist air so the problem is reduced or eliminated. Over the long run it costs no more to have a full tank than an empty one and it not only protects against condensation (for free with no additives) but you are prepared in case you need the fuel.
Water and diesel fuel constitutes a breeding ground for some life forms that live at the interface between the fuel and water, especially in warmer temps (not so much in harsh winter temps.) Products such as Biobor are algicides and will inhibit that growth. If you get the "black plague" growing in your tank you will have enormous filter problems until you eradicate the algae. You can end up with fuel filters clogging in just a few minutes, change to a new filter and get it clogged in a few minutes (lather rinse repeat.)
Pat
