BX2350 front tire chain info-homemade
   / BX2350 front tire chain info-homemade #1
PA-Woodchuck
Member
Western Pennsylvania
2008 BX2350 FEL
I have an old set of chains that I would like to cut-up to fit the front of my BX2350 with R4 tires. Could someone measure yours from sidelink to sidelink.
thanks
   / BX2350 front tire chain info-homemade #2
If you can wait until late March when they come off I'd be glad to. Otherwise just measure the width of your tire and add an extra 1.5-2 inches on each side.
   / BX2350 front tire chain info-homemade #3
Those are v-bars from tirechains.com on the stock R4s of my BX2350.
Thanks for the help, gives me something to do this weekend. Lask weekend we had 26inch of snow and another 8 on Wednesday. Do you also use a FEL with the chains on, if so how well does the front chains help out?
   / BX2350 front tire chain info-homemade #5
I have not had a load in the FEL since installing the chains. I just use the back blade for moving snow. When I'm pulling a full blade of this heavy wet stuff, going up the steepest part of my driveway, the tractor just barely starts slipping. I have chains all around but without the fronts, I'm sure I would have to back off a little. Last year, under the same conditions with no chains, I just barely made it up carrying the blade with the diff. locked. Almost had to abort and back down.
LIMA MAC 60KW GENERATOR (A58214)
LIMA MAC 60KW...
2018 Ford F-150 4X4 Crew Cab Pickup Truck (A55973)
2018 Ford F-150...
2016 Ford F-150 4x4 Pickup Truck (A54814)
2016 Ford F-150...
Forklift Safety Basket (A56857)
Forklift Safety...
2016 INTERNATIONAL DURASTAR 4400 (A58214)
2016 INTERNATIONAL...
2014 POLAR TANK TRAILER CRUDE TRAILER (A58214)
2014 POLAR TANK...
