PostHole Auger
   / PostHole Auger #1
Beltzington
Appling, Georgia
JD 3720
Going to build a pole barn and need to drill 20+ six-foot deep 12" diameter holes in extremely hard clay soil. I have done allot of reading and I am not sure the standard 3-point posthole auger is up to the task.
The Belltec looks like a good product but I am not comfortable spending $3K on a product I have never seen in use.
Rentals seem to be fence post related and I cannot find anyone who specializes in digging holes this size and depth in my area. Thought about calling a well digger but would not know what would be a reasonable charge for this service. Anything else I am missing? TIA
   / PostHole Auger #2
Most 3pt PHDs typically are set up to drill 42"-48" deep holes. There are extensions that you can put on to get down another 12"-14". Pretty hard to get down 6' though. These type of hole drillers were not intended to drill 6' deep holes. While I'm sure that it could be done, it would be a very difficult job, and not worth the investment for only 20 holes. The hardness of your ground is not really a factor, there are down pressure kits that will handle just about all types of soil, I don't think that the Beltic is your answer either, I don't think that it is set up to dig deep holes either. Unfortunately, you are probably going to be better off hiring this type of job out to the guy that is set up to do it.:( I have no idea about those costs, may vary quite a bit depending on circumstances.
Just my opinion, good luck.
   / PostHole Auger #3
The post hole augers used by the electrical utilities would work. they dig that deep. If you could locate a utility contrctor with this type of truck mounted auger that may be your cheapest workable way of accomplishing the task.
   / PostHole Auger #4
Depending on your situation you could get an excavator in to dig the holes. If you want just a straight hole down six feet that the previous post regarding the utility company to do it is a good idea. We have private contractors in our area that sub out to the hydro company. They are always looking for some extra income. Doing as many as 20+ hiring someone may prove to be the cheapest and fastest.
   / PostHole Auger #5
My Bush Hog 2102 has an extension for the augers as an option. Have to be careful that you have enough travel on the three point to lift the auger high enough with an extension.
   / PostHole Auger #6
I am curious where you are at. I know many places require 16"holes, at least at the base, never heard of any that required 6' deep holes. Is that what your local building department asks for?
MarkV
   / PostHole Auger #7
Even with your extension, how deep can you dig? My augers go 4' and I have a 14" extension. so that would be 62", he needs 72" I can't pull more than that out of the hole without going to extenuating procedures. What is your proposal? :confused:
   / PostHole Auger #8
Where we are about 1 1/2 hours north of North Dakota, the frost line is typically 6'. I think the majority of post frame buildings(and even lots of deck supports) are by code minimum 8' or more depending what you are doing. I think the concrete under my front porch is a 10' bell bottom hole with cement and rebar by code when they built my house. It was definitely easier/cheaper to get someone in and they put them in +/- 1-2 inches any diameter, I think they were very accurate.
Brent
   / PostHole Auger #9
In our area Bobcats can be rented with a PHD attached to the loader arms. Extensions for the augers can also be rented.
   / PostHole Auger #10
OK, sounds good, I thought that we were talking 3PT augers. :eek: A Bobcat would be the way to go, should be able to go 6' with little problem.
Pickup Truck (A59230)
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
SUV (A59231)
SUV (A59231)
Trailmobile Van Trailer (A56436)
Trailmobile Van...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
