Cheap Bridge idea
   / Cheap Bridge idea #1
Catch95
Australia
Jinma 204
I'm replacing an old timber creek crossing at present. After much reading and talking to others in the area, I've decided to use a flat rack (sometimes called flat deck) container. They are used here by emergency services for crossings when bridges are washed away in floods etc. I've attached a couple of pics - one in its raw state, and one that has been turned into a great looking bridge by a container company.
Obviously come in 20 and 40 foot versions.
Anyone else done this?
Mark
   / Cheap Bridge idea #2
That is a good looking bridge for sure. And should hold a lot of weight.
   / Cheap Bridge idea #7
   / Cheap Bridge idea
Sorry for not getting back to you - night time over here!
The are 8 foot wide. They would be available anywhere in the world that uses shipping containers. Some people prefer flat decks known as bolsters - same size, just don't have the fold down ends.
This link shows the diferent sizes etc Intramar Australia
From a container re-seller I was quoted around $2,000 (AUD) for a 20' and about $3,000 for a 40' bolster. The shorter ones can go on a tilt truck and be slid off easily - but generally these guys are so used to transporting containers, transport isn't an issue.
Will post some images when I get going with building the bridge.
Mark
   / Cheap Bridge idea #9
I have exactly the same problem (old wooden bridge) and had been thinking of using the bed from a flat-bed truck or trailer. This solution might work out cheaper, though.
Thanks for the idea,
BOB
   / Cheap Bridge idea #10
I used a 20' steel truck bed for a bridge across a creek on my property. It actually has 4' sides, & once in place we used a torch to cut out the forward bulkhead. I drive over it with a 40 horse tractor & in 4 years it has not budged. There was no cost involved because it had been left in one of my fields by the P/O, so I just drug it to the edge of the creek, then had a wrecker winch it over until it was in the right spot.
Containers, truck beds,bus/mobile home frames make excellent bridges.
RD
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
1992 Norris Long Basket Trailer (A55973)
1992 Norris Long...
2011 Toro Workman HD Utility Cart (A59228)
2011 Toro Workman...
FOUR WAY BLADE SKID STEER ATTACHMENT (A58214)
FOUR WAY BLADE...
2008 KENWORTH T300 FLATBED FUEL TRANSPORT TRUCK (A58214)
2008 KENWORTH T300...
JLG 20MVL MANLIFT (A58214)
JLG 20MVL MANLIFT...
