Tires AG tires on backwards
   / AG tires on backwards #41
My neighbor reverses his front tires in the winter to get better traction when blowing snow.
Makes sense when you think about it.
Yep, especially if the blower is in the back and going in reverse. :)
   / AG tires on backwards #43
When a tractor wheel is rotated outward the lugs are loosened from the slide rail on the rim and the clutch is engaged while applying the brake on the opposite side to be rotated. Most CUTS don't have this capability.
   / AG tires on backwards #44
You are referencing power adjust wheels... That is for adjusting track width, important for row crop. Having nothing to do with tread pattern direction.
as mentioned earlier....Turf tires are always going the right direction...
   / AG tires on backwards #45
My head is starting to hurt...I've decided to monitor my hour meter and drive forward for an hour and then back up for an hour...go back and forth like this all of the time and it shouldn't be a concern...plus, I'll probably get even tire wear! HA! HA! GENIUS!!!
   / AG tires on backwards #46
Unverferth Perfecta 26' Field Cultivator (A53317)
Unverferth...
UNUSED FUTURE SF60 60" HYD SIDE SHIFT FORKS (A57193)
UNUSED FUTURE SF60...
Miller Big 40 Portable DC Arc Welder Generator (A55973)
Miller Big 40...
STEEL SLINGS (A54757)
UNUSED FUTURE XJ5T 36" HYD THUMB CLAMP (A57193)
UNUSED FUTURE XJ5T...
Mahindra 4550-4L Tractor with Front Loader - 49 HP, 4WD, Heavy-Duty Utility (A55315)
Mahindra 4550-4L...
