Would you buy if didn't know the hours
   / Would you buy if didn't know the hours #1
TigerfaninAR
Gold Member
Central Arkansas
Kubota B2320 FEL, MMM
Would you buy a used tractor if you didn't know how many hours it had. Looking for a used tractor to leave at the land to cut the brush 4-5 times a year. Found a Kubota B8200 with loader, 4wd, but the hour meter is stuck at 460. Price is 5300.
   / Would you buy if didn't know the hours #2
I would say look it over real good like a vehicle. Check for blow by if you have a friend that is a mech have him go with you to check it out, check the oil level, drive it around. If the tractor looks beat up and run down I might would shy away from it(meaning high abusive hours). If its fairly clean(without being repainted) I wouldn't worry as much about it.
Just my .02
   / Would you buy if didn't know the hours #3
It would need to be a great deal and I would have to have no plans to sell it.
   / Would you buy if didn't know the hours #6
Yes,after close exam also who own the tractor.
   / Would you buy if didn't know the hours #7
I did.
   / Would you buy if didn't know the hours #8
Only my new tractors have accurate hour meters and most of the older tractors I have purchased I never believed them anyway. I look at the condition of the tractor first and foremost. If it doesn't look taken care of it probably wasn't taken care of internally either. I look for wear on linkages, draft arm wear at hitch pins, drawbar wear and engine wear.
Much more important than hours is care, least important is year built.
   / Would you buy if didn't know the hours #10
I did. Back in 1988 I bought an Oliver 77 at a farm auction. It looked really rough, too. Sheet metal was very rusty. The owner said the engine was overhauled the year before & had a Power Pack put in. The clutch was replaced. The dealer that did the work was there at the auction & confirmed what the owner said. The price was right & being a mechanic I was not afraid of it. I did a lot of work with that tractor (and on it) over the last 21-22 years & it owes me nothing. It runs great & always did. I finally had to replace the clutch last year & am now overhauling the PTO. I also overhauled the hydraulic pump twice. I'm sure I have put thousands of hours on it.
My point is if you buy that tractor be prepared to possibly do some repairs on it & buy it as cheap as you possibly can. If you're not mechanically inclined you need to factor in cost of possible repairs.
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2019 Dodge Challenger GT AWD Coupe (A51694)
2019 Dodge...
JLG E300AJ (A50123)
JLG E300AJ (A50123)
MARS AIR DOORS TAN BANK (A51248)
MARS AIR DOORS TAN...
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
