Soggy Ground What Attachment
   / Soggy Ground What Attachment
Could there be a natural artesian well underneath this soggy spot? Or, perhaps there is a busted waterline nearby that is seeping water up through that particular area??
thanks for the input, i don't think there is a well there and no one has water close to where i'm having trouble. But thanks for your thoughts and input.
Brian
   / Soggy Ground What Attachment #12
I would think sand would work better than silt, you want less organic matter in this case.
   / Soggy Ground What Attachment #14
Brian
An artesian well is a place where ground water naturaly works its way to the surface and doesn't necessarily mean a man-made well.
We have wet areas as well. We dug open ditches and one of them runs year round at about 2000 gallons per hour.
   / Soggy Ground What Attachment #15
That is a definite possibility, we used to call them flow wells in Louisiana. Some of them had very high flow rates. That was why I wasn't sure whether running a subsoil plow was a good idea.
   / Soggy Ground What Attachment #16
If the wet ground is over an artesian well or spring water a French drain won't work. It would simply fill and stay wet. The water would have to be tiled away.
   / Soggy Ground What Attachment #17
Hey Brian
I would use straight fill sand.
The deeper you rip it the better but if the top gives way you will have a slick mess and probably stuck.
Been there - Done that
If you cab get the sand mixed , you'll be surprised how quick it will firm up.
Hey Brian
Bill,
Well with the rain we got last night it might be a week before i can get a couple trucks back there, but i will call and get some prices on sand today.
It sure would be nice to have a tiller for something like this . . . maybe my wife will understand and let me spend a little green:D
again thanks for the help
Brian
   / Soggy Ground What Attachment #19
I don't know a whole lot about soil compositions, but after watching my neighbors I have a little idea. Their yard isn't low, but stays soggy for long periods of time after any rain.
The sand is a good idea, they bring in a few loads every few years and just spread it. It is a high traffic area and packs down pretty quick. Eventually it's covered in grass and you can't tell. I guess it mixes with the soil. However after an extreme amount of rain (like we've had here in Louisiana this winter) it becomes full of holes again from the traffic. The areas that don't get traffic stays higher and I can't really tell that it has a high sand content. I don't know if I'd build anything on it though.
Here's to wishing you dry ground :drink:
   / Soggy Ground What Attachment #20
I am a NOLa native I found dry ground in New Mexico years ago.:D
TEST YOUR BID BUTTON! (A51246)
TEST YOUR BID...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
UNUSED CFG INDUSTRIAL MH12R EXCAVATOR (A51247)
UNUSED CFG...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
2025 Safety Basket Forklift Attachment (A51691)
2025 Safety Basket...
