DiskDoctr
Okay you hydraulics experts. In researching the remote valve on my tractor, I noticed one number (4) is upside down from the rest (A16), so I researched "A16"
I have found what seems to be a name of an interface type (standard?). Here is an example from a google search result:
(I added the emphasis)
Is this a standard interface size/layout? If so, are valves with A16 stackable and interchangeable?
I have found "A16" popping up on a number of valves on a number of sites.
Hydraulics experts, what say you?
Thanks!
- JC
Sectional Valve DCV60 Series
1. Max flow: 60L/min
2. Max working pressure: 315bar
3. Working sectionas: 1~12
4. Threads: G1/2" (standard)
5. Spool stroke: +5~-5
6. Working section spools--S1: 3positions,double-acting
7. Spool control handle side--C2: handle at 180
8. Spool control spring cap side--A16: electrohydraulic control on-off voltage 24 volt c.c
Thanks!
- JC
