spray Pam on your snowblower to prevent clogging
   / spray Pam on your snowblower to prevent clogging #21
I've used silicon spray; made a difference with wet heavy snow. Also spray on my satillite dish; thats made a BIG difference.
That sounds like a good idea on the satillite dish. I'll have to try that.
   / spray Pam on your snowblower to prevent clogging #22
Did we just step back into the '40's? Where in the heck do they have commercial coal trucks?
Most electric power in the U.S. is still produced using coal as fuel. And there are many factories that produce their own power using the same. Not everyplace has access to rail delivery either. So, yes coal is still delivered by truck, train, an pipe.
   / spray Pam on your snowblower to prevent clogging #23
We still have a few home delivery coal companies around here. All of their trucks look like they're from the 40's, but they're still going down the road.
   / spray Pam on your snowblower to prevent clogging #24
We have TONS of coal trucks. Not all the mines are served by rail lines. Mostly tandem dumps with 2 drop axles. Almost always WAY overweight, they rut the roads up.
   / spray Pam on your snowblower to prevent clogging #25
Has anyone tried Fluid Film as a coating? It is lanolin based rather than solvent based so should act almost like a wax.
Just a thought. Here in the CA valleys there is not much snow - like never.
No, you all can move here after the terrible winter in the East. We have enough nuts already!:laughing:
   / spray Pam on your snowblower to prevent clogging #26
Has anyone tried this technique in the bottom of a wood chipper's discharge chute? I'm breaking my Wallenstein BX4 out next week and I'll give it a try when I chop up the twigs.
   / spray Pam on your snowblower to prevent clogging #27
Has anyone tried Fluid Film as a coating? It is lanolin based QUOTE]
X2 FLUID FILM is the answer if you want to spray and have it last. It doesn't wash or wear off quickly.
1 can of Fluid Film = 25 cans of Pam or silicon, etc.
   / spray Pam on your snowblower to prevent clogging #28
been using pam for 3 years and just switched to fluid film, hands down fluid film works way better and its stays on for a long time, it stays wet and doesn't dry.I used silicone before pam that seemed to wear off the fastest.
   / spray Pam on your snowblower to prevent clogging #29
I have not owned a snow blower that long but I fail to see how snow being thrown through the chute has a chance to stick to anything. When the snow comes out of my blower wet or dry it is MOVING!
   / spray Pam on your snowblower to prevent clogging #30
Use it in your loader when you have sticky clay you are moving around.
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
FUTURE D-PDQ 47" LAND LEVELER (A58376)
FUTURE D-PDQ 47"...
2013 Yamaha YDREX4 Electric Cart (A56859)
2013 Yamaha YDREX4...
Carry-On 5'x8' Trailer (A53316)
Carry-On 5'x8'...
2007 FRAC TANK 500BBL WHEELED (A58216)
2007 FRAC TANK...
2015 John Deere 5085E (A57148)
2015 John Deere...
