16-17LA Loaders
   / 16-17LA Loaders #1
paccorti
Gold Member
Hillsboro Virginia (near Purcellville)
TC35D with 16LA Loader
Has anyone seen the 16-17LA parts diagram? Part #21 is labeled as a "spacer". Is that a replaceable bushing? Has anyone tried this part?
Thanks,
Peter
   / 16-17LA Loaders
I'm curious how these parts would actually work. Unless you press fit them into the loader frame they could possibly spin (since the greased part of the pin would be only touching the inside part of #21).
Peter
   / 16-17LA Loaders #5
They are pressed in.
Rick, would you say these are field installable? Can I use a drift punch to remove them and maybe a big c-clamp to press in new bushings? Or is this one of those things that I should just bite the bullet and take my loader in to the dealer to have done? My main bucket pivot at the bottom of my lift arms is getting pretty loose.
   / 16-17LA Loaders #6
I would expect to cut them out with a bushing cutter or cape chisel, than drive the new bushings in with a bushing driver of the proper size (or suitable alternative), and a drilling hammer. A 'C' clamp would probably work if the thread on the lead screw weren't too coarse.
   / 16-17LA Loaders #7
Well Rick, just from your description, I think my dealer's shop is likely to have all the right tools and experience. I'm just glad to see that the 16LA has replaceable bushings. I think a trip to my dealer's shop might be the best way for me to go. It's about time I took my tractor "home" for a visit anyhow.:D
   / 16-17LA Loaders
Jim,
I'm in the same boat. I measured the bore on the main bucket pin and I got 1.3". The Pin seems to be 1.25" so I have .05" of play (almost 1/16" feels like more than it sounds like). Did you notice in the diagram that it says for some part number and later? My 16LA does not have replaceable bushings so I'm wondering how this would work. Do I bore it out to take the bushing? That seems dicey for me (at home) as you need precise alignment with the other loader bore (so that the bucket rotates around a common axis). When I was at the dealer the other day I priced these parts and I think they were ~$2.70 each.
Jim are you thinking of taking the plunge?
Peter
   / 16-17LA Loaders
Opps the picture does not say that. When I looked on the NH part website it said that (for part #21).
21 12 87028439 SPACER , P.I.N. YL365872 & After
Peter
   / 16-17LA Loaders #10
Jim,
Peter
Which bore did you measure?
How have you determined that your loader doesn't have replaceable bushings?
Electric Concrete Mixer (A51573)
Electric Concrete...
INOP Polaris 700 (A51573)
INOP Polaris 700...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR6BJ325793 (A51572)
2011 International...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2006 Ford Focus Sedan (A51694)
2006 Ford Focus...
Nissan CF60 6,000lb LP Forklift (A51691)
Nissan CF60...
