16-17LA Loaders
   / 16-17LA Loaders #11
How have you determined that your loader doesn't have replaceable bushings?
Rick, my loader is YL350697 and the parts list says this bushing is on YL365872 and after. That makes me believe my loader will have to be bored for the bushings to fit. That's probably true for Peter's loader too.
   / 16-17LA Loaders #12
I guess I missed that as well.
   / 16-17LA Loaders
Rick,
Good questions. On the picture I measured the leftmost lower bucket bore. I must admit I took just a few measurements (for example I didn't get max and mins and did not measure vertically). Last weekend I actually took apart the entire 4 link area and cleaned my ten years of accumulated grease and dirt. It certainly did not look like the bores are replaceable (although if they are pressed in it might be hard to tell).
The other option of course is to have a new over-sized pins made. Out of curiosity what is the optimal fit (how tight should it be)?
If I had my choice I would re-engineer how these pins work. I'd like a mechanism which actually traps the grease between the bore and pin say an "O" ring fitted to both pin ends (just inside the bore). Since the old grease couldn't be pumped out of the bore (past the "O" rings, I'd create a relief port (much like the grease intake) that permits old grease to exit ultimately from the center of the pin (opposite the intake side). I'd fit this exit port with a screw that would trap the grease. When you grease the tractor you'd remove the screw to permit the old grease to be pumped away. Otherwise the screw would be in and trapping the grease until the next change.
Peter
   / 16-17LA Loaders #14
Rick,
Peter
The bucket mount pin bores are not the primary wear point. The pin is trapped by the cross bolt and does not rotate in, or wear significantly on, the pin bores mounted to the bucket. Also true of the loader boom mounts bolted to the midpoint of the tractor.
You can do as you wish, but for my money you are overthinking this by a huge factor. Loader pins and bushings are not meant to be a close machined fit, and creating close tolerances in these areas has a highly unattractive cost/benefit ratio. Frequent applications of modest amounts of whatever grease is readily available is all that is required to keep everything working properly for years or thousands of hours.
   / 16-17LA Loaders
LOL half the fun is over-thinking these things! As you can probably tell I'm a nerd at heart and not really happy unless I have some problem to solve. When I said bucket bore I did mean on the loader frame and not the bucket itself.
Peter
   / 16-17LA Loaders #16
I put a complete set of these in my loader without pressing them in. I drove the old ones out with a punch and seated the new ones in with a scrap piece of steel and a hammer. It doesn't take much to replace them.
   / 16-17LA Loaders #17
I guess I have to disagree Rick. I know I have used my pre-bushings loader hard, but I also greased it alot. The bore holes in the loader arms for the bucket do wear. Once they start to wear, they hold grease ever more poorly -which accelerates the wear. My pins look like new! It makes no sense whatsoever to have harder pins than non-renewable bores, that is an absolute bassackwards design flaw.
Dave.
   / 16-17LA Loaders #18
Dave.
You are disagreeing because you did not comprehend what I posted. I wrote that the pin bores in the BUCKET are not the primary wear point.
   / 16-17LA Loaders #19
Fair enough. I did overlook that.
Dave.
   / 16-17LA Loaders
PoleClimber,
The two bearings are not as wide as the loader frame's total width. Did you press the bearings all the way to the center of the bore or did you press them in until they were flush with the frame. The bearings seem to have a very tight fit to the pins (which will be nice).
Curious,
Peter
2017 AUTOCAR YARD SPOTTER / TRACTOR (A52576)
2017 AUTOCAR YARD...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2000 Toyota Tacoma Pickup Truck, VIN # 5TEWN72N6YZ690085 (A51572)
2000 Toyota Tacoma...
2013 Chevrolet Caprice Sedan (A51694)
2013 Chevrolet...
2025 New/Unused Wolverine Snow Pusher (A51573)
2025 New/Unused...
