Necessary to purge the lines ?
   / Necessary to purge the lines ? #1
Arky217
Hartford, AR
Kubota L4200
Hi,
I'm nearly ready to attach the hoses from a bucket grapple arm cylinder to one of the hydraulic remotes at the rear of the tractor.
My question is: Do I need to 'crack' the fittings at the grapple arm cylinder when I first operate it to purge the air out of the hoses, or will it self purge after operating it a few times ?
Thanks,
Arky
   / Necessary to purge the lines ? #2
Do you crack it when attaching to the fel? If not, why would you need to to connect to the rear remotes?
I have no idea, since I've never had the FEL off. I've just not worked with hydraulics before. From what you said then, I assume that the answer is no, it's not needed, and that it will self purge.
Thanks,
Arky
   / Necessary to purge the lines ? #4
It will self purge after operating it a few times...
   / Necessary to purge the lines ? #5
What he said! The system is self-bleeding, the air will be pushed towards the sump.
   / Necessary to purge the lines ? #6
Just make sure the tractor is NOT running when detaching or attaching any hydraulics. Hydraulic fluid is under high pressure when the tractor and hyd pump are working and when stopped there is still pressure in the lines, which is why it is sometimes very difficult to connect some hydraulic fittings. The detent balls are in the fittings to keep the fluid from leaking out. I suggest wearing gloves when working with fittings just as a precaution. Beware that gloves will NOT stop hydraulic fluid under pressure, when the system is running or springs a leak, from cutting into skin- and if that ever occurs it requires IMMEDIATE medical attention.
Better safe than sorry. Study up in the hydraulics forum to learn all safety issues surrounding hydraulics/fluids.
2016 Toyota Prius Hatchback (A53424)
2016 Toyota Prius...
2013 Ford F-550 4x4 Ext. Cab Service Truck (A53422)
2013 Ford F-550...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A53421)
2023 Caterpillar...
New/Unused Sd Lanch SDLJC Mobile Jaw Crusher (A54865)
New/Unused Sd...
JMR stump/trenching bucket (A53421)
JMR...
2007 INTERNATIONAL 9200I DAYCAB (A55745)
2007 INTERNATIONAL...
