Replacing the water pump bearings on Yanmar YM2000
   / Replacing the water pump bearings on Yanmar YM2000 #11
Hi I am new to the forum and not really know English, I come from Polish and need help in dismantling YM2000 Yanmar water pumps.
Some time ago bearings in the pump started beeping and I want to mention them, just do not know how?
Maybe someone undressed and will share how to dismantle?
Do I need to use the puller and the gunboats from the fan?
Thanks for any help:)
There is not much to it. You will need a gear puller and maybe a "C" clip tool. Remove everything from the front of the shaft and push the shaft out the back. Bushings are probably held in by "C" clips. You just need to be a little bit mechanically inclined.
Hot or> heat burner and then download it to the front wheel.
,, normde2001 "whether the front wheel does not have any collateral?
   / Replacing the water pump bearings on Yanmar YM2000 #13
This sounds like a job for MJPeterson:).
I agree. I don't think Babelfish (internet translator) is going to be sufficient for this!
Guys, I think we need to use only very simple Basic English that will pass through an online, automated translator and come out the other side making sense in Polish. Otherwise this will just be a thread about language, instead of helping him with the water pump.
I think the question is: "Do you need to heat the fan hub to get it off the shaft?" Also, "is there anything holding the hub on ("collateral") that needs to be removed first?". Piotrbpm, did I understand that correctly?
   / Replacing the water pump bearings on Yanmar YM2000 #14
:laughing::laughing::laughing::laughing:
What he is wondering is if the impeller is installed hot. That is that it is heated and then pressed into position. I will try to help him. Does the service manual cover rebuilding the water pump? Probably not just replacing it right? I will see if I can get a parts manual for him. I do not have time to get a service manual.
norm; I have not had one of these pumps apart, so do not even have a clue without a picture. What do you mean by "back" and "front"? Front as in the fan/radiator side? Back as in impeller/block side?
Mike
   / Replacing the water pump bearings on Yanmar YM2000 #15
No need to heat anything, some have a circle clip, some don't. A new pump W/gasket is a little over $ 100, if this is your first time, you stand a real good chance of busting the housing. If he buys a bearing & shaft, impeller, seal, and gasket it may not be worth it.
Danny
   / Replacing the water pump bearings on Yanmar YM2000 #16
Mike
I would assume the fan end to be the front.
   / Replacing the water pump bearings on Yanmar YM2000 #17
Like I thought Norm, just checking, because the pic on Hoye's site indicates that the bearing and shaft come out the front.
I am posting the pic so that everybody will be on the same page. I now know more than I did, from what norm said and looking at the pic. :thumbsup:
Mike
   / Replacing the water pump bearings on Yanmar YM2000 #18
Mike
It's a similar job to this . The wheel puller will probably press the shaft out, rather than a shop press, and you can't separate the impeller from the shaft without first pushing the shaft out, so . . . no need.
Hello again, I will try to dismantle a welt:) For now understands everything so sorry mauling sentence: /
   / Replacing the water pump bearings on Yanmar YM2000 #20
No big deal. Nothing MJ and others can't figure out what is being asked or said.Now post something like this ヤンマー株式会社, Yanmā Kabushiki-Gaisha any almost everyone will be wondering,
What the :confused2::confused2:
Translated so it shows that it doesn't hold any profanity :p
ヤンマー株式会社 | Yanmā Kabushiki-Gaisha is a Japan ese company involved in the manufacture of John deere's small diesel engines :laughing::laughing:
PALLET OF SITE FENCE STABILIZERS (A51248)
PALLET OF SITE...
2023 Jeep Compass Trail Hawk 4x4 SUV (A51694)
2023 Jeep Compass...
Bobcat 873 2sp Skidsteer (A52384)
Bobcat 873 2sp...
1986 Wisconsin 24' Tilt Deck Trailer (A52384)
1986 Wisconsin 24'...
UNUSED LANDHERO LDHGAC40V AIR COMPRESSOR (A51248)
UNUSED LANDHERO...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
